    Votes: 116 24.5%
    Votes: 357 75.5%
  • Total voters
    473
fabio
1,885
4,325
Are you using a bottom mounted rad (I've lost track of your current config)? That's how mine is currently set-up.
I think the increased distance between desk and intake mesh is improving my temps by a noticeable amount.
No, I’ve changed the stock one because were leaving a lot of mark on my desk! :D
Reactions: bricemx
xkruz
61
106
Has anyone tried magicool 240mm G2? I have one, and curious to see wether it fits or not because it have the same thickness with ek classic (on fabio's) 27mm
kmnvhs
21
instagram.com
Why can i preorder one only if i write a commend? I follow this thread since the vid. from optimum tech and i am so fucking hyped! But i dont write any commend because im not an enthusiast like other guys here in this tread. I love thats a very premium build case thats woth the money.
It would be a very nice challenge to build in after my exp. with the A4SFX, M1 V5 & V6.1 and Ghost S1.
hitsuyounai
45
I apologize if this has been asked already (also tried searching the thread, no definitive answer).
After preorders open to the masses in June, what kind of timeline are we expecting to receive the cases upon placing our order? Assuming factories resume doing factory things before then. Not entirely in a rush, just wanted to plan out things in a timely manner.
DaKluit
Sorry to drop in a post here. But it seems i have to, to fill in the form. Bit weird, but ok. Now ill go back to lurking this thread, keeping this thread as clean as possible.
Btw, is there some way to hide all post from people who just post because they need to have a post for the form? Makes it easier (for me) to read the important stuff.
xkruz
61
106
Quick magicool 240 G2
Asus x570i
Ryzen 9 3950x
Ek supremacy classic RGB AMD CPU Block
2x noctua chromax black 12x15
Magicool 240 g2
Some cheap chinese ddc pump
Open test bench
Temp after 5 cinebench run max @76° C (27°C ambient)
This is with no GPU because I want to pair this with radeon VII, and ekwb block doesn't fit in my current setup (ghost s1) because it was to tall..
I See in others build, T1 has little more gpu clearance than ghost s1, hopefully I can put ekwb radeon vii block inside T1.
If not, I need to buy alphacool radeon vii block, because it is shorter by 2cm (fit in the ghost s1)
hitsuyounai
45
There isn't actually a "need" to post. The form you filled out are meant for the backers/followers who have kept up with the T1 since it's origins back in late last year.
Gerold
160
172
www.instagram.com
No you can't filter out these posts - and that's exactly why a discussion about spam posts arose.
Read through the first 280 pages and you are good. :)
gwertheim
938
1,555
Get out your magic 8 ball, because nobody knows the answer that.
  • Haha
Reactions: fabio and Doppler9
xkruz
61
106
The new EK Momentum might be worth for that CPU. It's expensive, but the best for Ryzen 3000 atm.
Monoblock? I think mine was fine.. I have one block from previous build, so why not?!
I've found monoblock+ddc pump for x570i aorus on taobao, and I will get it arround 1 month from now..
I'll test that, because it seems bellow 48mm limit.
Or I can just use the 2 slot card mode
Reactions: bynio
blindphleb
79
107
I'd argue it's silver. Can't comment on the two tone though. :)
I see in the first page that the all silver case is shown with the machined slotted silver side panels. But I think I remember seeing some tests with chromed mesh too. Does anyone know how that turned out?
