For anyone that can understand Mandarin. Not as cinematic as Optimum’s video, but much more informative. There is supposed to be a ‘Part II’ coming, which compares different cooling options, such as top radiator vs. bottom radiator. Credit goes to ‘suming li’ on YouTube and please subscribe if you like his contents. Enjoy!
Distro plate question: compatible with a monoblock? (e.g. EK WB monoblock)
Thanks,
First page, first post, you can see some other color schemes he is intending to look into. Two-tone is definitely coming, a pure silver might be coming, and a pure white version might be coming.This is looking exquisite, guys!
Been lurking for a long time now and eagerly anticipating this case.
Have you thought about some other color schemes too for this case? I tried searching but couldn't find much if any.
I can say that for sure I will take the pump and reservoir OUT. Just because I have a dead space in my desk, and make everything easier in the inside.So, which iteration do you plan to keep in the end? Is there a particular one you recommend in terms of space efficiency/practicability/performance?
If you really want to go on the SMALLER side, THIS is the tiniest option you have, and still giving you a top port to fill the system.The one i am using is the dc-lt 80, https://www.performance-pcs.com/wat.../alphacool-eisstation-80-dc-lt-reservoir.html, I figured for my first loop it would be a little easier to work with a bigger res so I could bleed the air out easier. Plus, I couldn't find the 40 in stock anywhere and I was already 3-4 weeks waiting for parts.
The one fabio is using is the dc-lt 40, https://www.performance-pcs.com/wat.../alphacool-eisstation-40-dc-lt-reservoir.html.
I'm not sure the dc-lt 80 will fit. I'm in a sliger sm580 so I have quite a bit more room to play with than the T1.
To clarify none of these are necessary if you plan to use the LT 240 just more options and it would make filling slightly easier.
www.aquatuning.us
Stay with the 2600rpm.![]()
Alphacool DC-LT 2600 Ultra low noise Ceramic - 12V DC
Alphacool DC-LT Keramik 12 Volt Pumpe Low Noise, die Miniausgabe einer Pumpe mit viel Dampf im Kessel! Wasserkühlung im Allgemein ist nicht nur für Bigtower und im Highendbereich zu Hause. Auch Barebones, HTPC oder Desktoprechner...www.alphacool.com
Alphacool DC-LT 3600 - 12V DC - Pump - Industry bulk
Alphacool DC-LT Keramik 12 Volt Pumpe, die Miniausgabe einer Pumpe, mit viel Dampf im Kessel! Wasserkühlung im Allgemein ist nicht nur für Bigtower und im Highendbereich zu Hause. Auch Barebones, HTPC oder Desktoprechner wollen mit...www.alphacool.com
Which pump is better? Noise, cooling efficiency. Thanks
YES! Right now you have 2 option:Hopefully no one else has asked this question, but is there a pcie 4.0 compatible riser that will work with this case?
I know nothing really takes advantage of it, but at least on the gigabyte x570 board if you run a Navi card with a riser you need to set the pcie slot to 3.0 instead of auto to avoid some problems. Having a pcie 4.0 riser cable would avoid that step.
This of 30cm length:
LINKUP Ultra PCIe 4.0 X16 Riser Cable [RTX3080 x570 B550 RX6800 Tested] Extreme High Speed ITX Vertical Gaming PCI Express Gen4 2020 | Straight Socket {30 cm} 3.0 Gen3 & TT Compatible
New 2020 PCIe 4.0 revision. No BSOD, or WUE / WHEA Error free. More headroom works for overclocked CPUs and GPUs. LINKUP Riser Cables feature technology used in the construction of OCuLink, 8639 U.2, and SAS cables that are tested to reach speeds of 160GB/s for the sum of all x16 channels...linkup.one
And this, 25cm, super tight fit!
I prefer include in T1, rather must buy again in another store, since my customs in very unique.. i"m okay if i must pay more for PCie 4.0 @Wahaha360
I´ve tried both of them and the 3600 version is noisier (and not a little) even at the same rpm than the 2600 rpm version. The difference is quite noticeable, I would advise not to buy the 3600 version, you would be better trying to fit two 2600 if you can, it will be silent and have enough pressure. Take in mind that alphacool has both cpu and gpu blocks with this pump incorporated, so you can play with all those factors.
Hmm this explains the noise in my GPX Pro Solo..it's pretty quiet but not as quiet as I'd hoped. But it's hard to find ultra noise version of DCLT in stock. Has anyone found a good source for them? Of course, I think I'll go DDC route.
