    Votes: 116 24.5%
    Votes: 357 75.5%
  • Total voters
    473
Yugo555
71
26
Will there be any Europe retailer or possibility to buy in Europe? I personally don’t wanna deal with customs. I am willing to buy from European retailers everything included.
Navic
587
1,341
Most likely not. For people in China I think the creator is making a shop specifically for them. Everyone else will have to use the website, where it will ship from china.
Reactions: Yugo555
fabio
1,885
4,325
Here the specs and imgur album! Soon the build log in the Build section! ;)
AMD Ryzen 3950X (PBO Enabled like in the latest Buildzoid video)
Gigabyte Aorus X570 ITX
Corsair 2x32Gb 3600MHz C18-20-20-40
Nvidia Titan V (watercooled)
Nvidia Titan RTX
Samsung 970 Evo Plus 500GB (OS)
Samsung 970 Evo 2TB
C_Payne Bifurcation Riser x8/x8 1-Slot
ADT.lnk 90 degrees Riser R33L 25cm
Corsair SF750
PSlate custom cables+my own custom cables
EKWB Magnitude Acetal+Nickel CPU Block
EKWB SE240 Classic Radiator
EKWB Titan V GPU Block+Backplate
EKWB 90 degress Torque fittings
Barrows Offset Fittings
Alphacool TPV Metal fittings+2 TPV 90 degrees fittings for the GPU
Alphacool TPV tubing 12,7/7,6
Alphacool Eisstation DC-LT 40 Reservoir_DC-LT 2600 Pump
Noctua F12 Chromax
Noctua A12x15 Chromax
Noctua NA-FC1 Fan PMW controller
panzermuffin
100
171
Here the album! Soon the build log in the Build section! ;)
Wonderful build!
Can you link those stubby antennas? Also do you have/had random disconnects on your X570 I Aorus? I'm using this mainboard since a week and my Wifi randomly drops.
bynio
70
74
Wonderful build!
I'm using x570 aorus for months and wifi is fine, but I'm on original fin antenna.
Reactions: fabio
fabio
1,885
4,325
Wonderful build!
Thanks man!
No WiFi problem so far. The antennas are always from Taoglas. They also have a 90 degrees version of them!
Reactions: MultiDoc
Navic
587
1,341
I live in Australia. How do I go about buying this case?
Pleas check the first post. Once all the test shippers get their cases and give feedback, and once the creator is comfortable about releasing the case to the masses, it will be available on the website, that has not been released yet.
Reactions: pwnedundies
Brude27
381
878
I swapped out the Alpenfohn Black Ridge v2 cooler for the Noctua L12S today, and learned a couple of things while doing so that could help some of you future builders:
  • The L12S doesn't fit the ASRock Z390 Phantom Gaming ITX motherboard without slight modifications.
    • Either the fan needs to be filed down (what I chose to do)
    • Or the VRM heat sink needs to be removed
  • The L12S only fits in one orientation in this case with my motherboard.
    • The bottom strut obstructs the recommended orientation for the heat pipes with the case flipped.
    • I'm not sure about other motherboards, but horizontal cooler orientation could fit in the case if you're using low profile RAM and your board doesn't have anything that could get in the way.
I only had a chance to run one stress test before I was occupied for the rest of the day, but it looked pretty damn good for the L12S. I'll post proper comparisons when I get a chance to run more tests... hopefully tomorrow. :)
LCK sb
28
Nvidia Titan RTX
Samsung 970 Evo 2TB
Corsair SF750
Noctua F12 Chromax
Nvidia Titan RTX
Samsung 970 Evo 2TB
Corsair SF750
Noctua F12 Chromax
Excuse me, what is the model of the two parts of pcie
AP2
291
325
im using the Quadro NVLink for a 3 slot setup. Also have a cpaine burfication card I will be using in the T1.
Proflucifer
92
42
QQ App, group chat, search for 837637024
Found the group chat. I pressed apply to join the chat. What do I do next? Do I just wait to be let in?
Edit: QQ PC is wack. QQ is weird. Im in in mobile QQ and they made me change my password. QQ is weird.
