Then I think the limitation is in BIOS only. Good to know!Mine is an Asus Z390-I (not your B450-I) which has Fan Xpert 4 (within AiSuite 3) and it allows you to adjust speed curve for the AIO pump header (all the way down to 0%). Maybe yours can do it there. Try it, no harm.
Do you hear a noise when you shake your radiator? If yes that mean they are still some air in it-I've installed the LT240 but temps are not great at all. I'm assuming its either poor contact or some remaining air in the system. I used the noctua secure mount from my C14S but even with the AM4 washers, the LT240 screws seem to run out of thread. Anyone else had this issue?
-I'm stuggling to set a static pump speed on my Strix B450, I know the pump is DC only, but I can only have control by plugging it in to the chassis or cpu fan header, the aio header is 100% pwr only.
Well, now I want to know all the other secrets! If only were existing a 1-Slot NV-Link!
I've added the QUADRO to control the fans! Because with one Y splitter the PMW input does really what it wants! BUT, I've fucked up the QUADRO. I've inverted the 5V and 12V cable, and has burnt.What do you want to add in this space
Thanks for the replies guys.Finally!! So happy man! Following quick replies:
Don't know why you have used the Noctua stuff. for the AM4, just follow the Eisbaer Manual! Stock AMD backplate, that's it.
From what I've heard the mesh is actually quite stuff, so it might be hard to fit it in they're, plus I don't think making it bulge outwards would make a good look. No way to tell yet, mines stuck in shipping.if I was to do this with the 3-slot GPU mode, and since the pump extends 2.9 mm, it would mean the side panels won’t close right? How tough is the mesh on the side panels? I imagine it would bulge out a little if the side panel was indeed closed?
By design, yes.Does this case feature a motherboard cutout at the back?
Can't yet. There will be a website where you can get it from once the creator feels comfortable putting it up for sale to everyone.How to order this case ?
Yes, I will!@fabio (and any of the other test shippers really) do you plan on making a separate build log in the builds section? It would make it easier to see everything you’ve done inside the T1 and any feedback/advice you might have. This thread is only gonna keep growing, which will make it harder to find your info.
I've seen it! But this is like a 1-0-1 Nvlink. I would like to have the 1-1, but doesn't exist in the e tire marketThis is what nemeses used, quote from his post
"Luckily PNY makes a 3 slot bridge for the Quadro RTX 6000 and 8000 which also fits and works for the 2080Ti (Product ID RTX6KNVLINKX16S2RKIT)"
I've seen it! But this is like a 1-0-1 Nvlink. I would like to have the 1-1, but doesn't exist in the e tire market![]()
I think will be possible only if I remove the 240 rad brackets. But In any case I don't have a second Titan RTX, so for now everything is ok!Ohhhh I see. Well... Can you water block both cards and somehow use a 1-0-1 spaced bifurcation riser?
