    Votes: 116 24.5%
    Votes: 357 75.5%
  • Total voters
    473
Nyanino
Really looking forward to building in this case when you launch! Excited to see some of the accessories that come out of the case as well. It looks like on the back of the case there's a G14 hole, wondering if this could be blocked with something. Both the holes are for power button orientation, right?
Navic
587
1,341
New question! Will it be possible to set the case in 3 slot GPU mode, use a 2 slot card, and leave a channel behind the card for cable hiding/management?
Good question. I doubt it? But I'm not sure. I think you could maybe use the 2 slot standoff for the PCIe riser and use it in 3 slot mode and get space behind the GPU for cables.
If I remember, I'll check once I get mine and let you know, or someone else can do that because I'll probably get my case a lot later than others.
fabio
1,885
4,325
Today was a long day!
FInished to test the loop, and everything is working perfectly!
The Pump is super silent between 60 and 80%!
I still hate the chipset temps. They stay always between 70 and 85, it depends from idle and load. Hoping for the B550 or maybe switching to the Gigabyte?
But man, this is my first GPU on water, and it's INCREDIBLE how much stay cool compared on air!!
Tomorrow maybe i will test the DC-LT to see the difference in temp. noise and flow!
fabio
1,885
4,325
Ive read that Asus has been forgetting to put thermal pads under the chipset heatsinks of the x570 boards. Might be worth having a look to be sure.
Mine has it, I’ve also replaced it, but nothing has changed. The fan does anything, just noise
  • Sad
Reactions: Sh0ckwaveFlash
DrHudacris
918
1,720
Which radiator is that?
F7IN
39
57
I've been checking this thread for shipping/ preorder dates since January. Finally decided to just make an account for here so I can get a notification instead. Can't wait to have an SFX case that'll hold my Strix 2070s
Kundahli
126
77
What pump/block are you using there?
Hardly
Has any test-shippers gotten a shipping confirmation? Getting paranoid over putting the wrong information in the order haha..
haroldngkh
Will the AORUS 5700XT fit in the Sidearmd? Website says to remove 15-20mm from 140mm max GPU height due to the PCIe riser. The AORUS is 123mm tall.
Brude27
381
878
Nothing yet! I'm sure logistics are proving to be challenging, and the fact that the power button manufacturer came through at the last minute makes me think we might also be waiting on that. I know @Wahaha360 gave us the option to PM him if we wanted to wait, but I know I personally would've held everything up for the sake of saving on shipping costs. There's no reason to not wait a week and only pay for shipping once vs twice.
Theai
40
Is it possible to know when the preorder is open?. Are they going to make some changes to the case to make enought room for the 240 and fans to fit
PBJ
358
546
Actually, it says to allow 15-20mm for the gpu’s power connectors. The power connectors on that card seem to be a bit recessed, so I’m guessing you should be ok.
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
Update 2020-03-02 : Waiting for power button to arrive this week before shipping to Test Shipping Candidates!
Australia, Wyd4
Austria, Cyberratchet
Canada, johannbl
Denmark, fabio
Finland, Benihana
France, Vaux
Germany, theexplainer
Japan, hengster
South Korea, ahs8225
Italy, Metroversal
Malaysia, chinyang
Netherlands, Floris
Poland, bynio
Portugal, nulio
Saudi Arabia, darky122
Singapore, heckinwoofer
Spain, prava
Sweden, hardly
Taiwan, Thermo *special consideration, working on a T1 accessory
Turkey, cablez
New Zealand, tyen
Norway, Stigth
Ukraine, denys_349
United Kingdom, Goatee
USA - California, bpark919
USA - NYC/CT/MA, Kundahli
USA - Texas, Navic
USA - Texas, DrHudacris *special consideration, many posts thread
USA - Other, PBJ *special consideration, many posts thread
USA - Other, Brude27 *special consideration, many posts on thread
USA - Other, pslate *special consideration, custom cables for T1
Uzbekistan, Basriy *shipping to Uzbekistan is exotic to me
FWIW, the power button is flat and flush to the back of the case, which makes it at least unique among Vandal Switches, which typically protrudes out of the mounting surface. In case you are wondering, yes, it can be used on other cases with 16mm hole cut out as well - so it's not custom to the point of incompatible.
PBJ
358
546
Australia, Wyd4
Canada, johannbl
Denmark, fabio
Finland, Benihana
France, Vaux
Japan, hengster
Italy, Metroversal
Malaysia, chinyang
Netherlands, Floris
Poland, bynio
Portugal, nulio
Spain, prava
Sweden, hardly
Turkey, cablez
New Zealand, tyen
Norway, Stigth
Ukraine, denys_349
USA - Texas, Navic
Gonna be worth the wait!
EDIT: Please let us now when you have a new shipping estimate
Reactions: Brude27 and race2c
AMv8-1day
228
193
Q4/2020 on the other models?
Is that just a rough guesstimate while you deal with the uncertainty of production/shipping right now? Or are you planning to step back and concentrate on other projects for a minute?
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
Guesstimate while I deal with production for next batch of Black T1 with Mesh.
Reactions: AMv8-1day
