I wanted to get a post in here to let you know that I am super excited for this case and cannot wait for pre-order to go up!
In terms of opinions/feedback, I do wish the case was 10mm taller AIO side, which would have still be under 10L (9.91) but permitted 240 usage more easily.
I love the design of this case as I feel like the price / layout / features / aesthetic of something like the SM570 misses the mark where this hits it!
I think you see so much obsession around 240 because its a more common product size from the popular cooler manufacturers (eg: Kraken X52, etc.) and less about its being "more thermally efficient".
Again amazing work!
Something I wasn't sure of, will we be able to select different panel types at pre-order?
Ahh I see. Thank you for the info! I thankfully have some Corsair LPX, so hopefully that should work. Thank you for all of your help!Be careful with the memory height also. With the trident Z and the low profile fittings there are clearance issue. If you use lower memory height works with no problem!
Definitely. I was looking at a photo of fabio's Apogee with an Alphacool block and it seems larger than 50 mm for the 3 slot GPU mode. I have a 3 slot card unfortunately, but I am considering making a loop in the T1. In which case, I'm 100% using that as my pump/block combo. I really like the metallic, gun metal look of the Alphacool DDC pump.I think it will probably fit, but you will be limited to the 2 slot GPU mode.
Only other question I can think of is: what is the diameter of the switch opening, for using custom vandal switches?
Uhh, let me preorder please! ?
Again amazing work!
Might I interest you in this thread? I think you'll be a happy camper once you get through all the pages on that one.![]()
If I’m not wrong, the initial vision for T1 is cpu cooling with 120mm aio or more powerful air cooler ie L12S with a 3 slot air cooled gpu.. however, as a bonus, it turns out it can support a 240mm rad albeit with some hardware limitations..
Judging by the response on building a custom loop with 240mm rad, I think it’s fair to say everyone wish T1 had taken a bit of ****** and grew a bit bigger ?
Not me.If I’m not wrong, the initial vision for T1 is cpu cooling with 120mm aio or more powerful air cooler ie L12S with a 3 slot air cooled gpu.. however, as a bonus, it turns out it can support a 240mm rad albeit with some hardware limitations..
Safe, if you put a mask yeah why not?Would it look good and be safe for me to spray paint the mesh panel blue? I want a case that would fit a white and blue theme and the mesh panel is black.
If I’m not wrong, the initial vision for T1 is cpu cooling with 120mm aio with a 3 slot air cooled gpu or more powerful air cooler ie L12S with a 2 slot gpu.. however, as a bonus, it turns out it can support a 240mm rad albeit with some hardware limitations..
Edit: L12S + 2 slot gpu
smallformfactor.net
