    Votes: 116 24.6%
    Votes: 356 75.4%
  • Total voters
    472
Sebbie
47
28
You can fit it with some modifications according to @Wahaha360
What said modifications needs to be done?
I dont plan on using the LT240 since its crap, i only need the radiator from the AIO, since its 25mm thick.
i would wait until the Optimum Review or Official information's at the website or by @Wahaha360 .
Sure, the case cannot be purchased at this time anyways.
hetvler
204
153
What’s crap about the LT240?
PBJ
358
546
You just need to ditch the anti-kink coils from the tubes as they don’t allow for tighter bends.
I was under the impression that the pump/ block was also pretty good. It is appropriate for a single radiator loop.
Vaux
96
123
I just received my lt240, and I think the problem may be that the tube are too long, especially with the quick disconnect attach on it who add even more bulk, the anti kink coil doesn't stiffen the tube that much
I would try to fit it as is, if it doesn't work I would change the tubing
Reactions: PBJ
PBJ
358
546
I see, thanks for the info! Let us know how it goes when you get the case.
Sebbie
47
28
The pump/block combo is just bad, im a bit of a noise freak and compared to e.g. The Swiftech Apogee its just bad.
and if you dont plan on swicthing/adding new stuff in your loop QDC isnt worth it since there is a risk of leaking there.
That being said alphacool radiators has always been my go to :) so thats why i only need the radiator and make my own custom loop.
Vaux
96
123
That's not what was saying Optimum Tech on this video:
Also for having testing the pump out of the box, it was perfectly silent once i dealt with the vibration (at first I had the block directly on the wood desk, then I added a packaging foam sheet underneath, didn't try installed on a system tho )
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
@Wahaha360, whats the distance from the 3pci slot to the inside panel? seeing if I can stuff 2 single slot water-cooled 2080tis.
See this post.
From the back of the GPU PCB (not including backplate), to the side panel, 59.2mm.
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
Two different answers, do it fit or not?
I dont need an official support, i just need it to fit with slim fans :)
The Ncase M1 dosent official support a rad at the bottom part of the case but it can still be done :)
[/QUOTE]
The LT240 is not officially supported, but you can fit the LT240 by 1) removing the anti-kink coils, 2) shortening the tube.
Both requires opening the loop, which also implies removing bubbles, and that makes it not beginner friendly. With people constantly asking for size increase to accommodate a thicker 240 radiator, we officially drop it from being supported.
I'm trying to put together a 3950X + RTX Titan build on modded LT240 soon.
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
T1 Black + Mesh Availability: sidearmd.com, preorder after OptimumTech video, shipping date target 2020-Feb-15
T1 Black + Mesh Price: USD 200, excluding shipping (Free to USD60 depending on shipping speed and country)
T1 Black + Mesh Side Panels Specifications:
Material:
CNC machined from 10mm 6061 Aluminum + 1.5mm steel SFX and Fan brackets
Side panels: ultra-fine mesh side panels (also functions as dust filters)
Colors: Sand Blasted + Anodized Black Aluminum chassis, Powder Coated PSU and Fan brackets.
Dimensions (W x H x D): 133 x 216 x 330, 9.48L
Graphic cards support: Three-Slot Slot GPU up to 315mm, 60.8mm from Side Panel to GPU PCB (including 1.6mm GPU PCB)
Motherboard support: Mini-ITX
Power Supply support: SFX
CPU Heatsink support: Up to 70mm height (Noctua L12S recommended)
Water cooling support: 120mm AIO at 35mm thick
Drives: 1 x 2.5" HDD/SSD
PCIe Riser: Included
Navic
587
1,341
If you ever find out from OptimumTech, could we get a time and timezone that the video will come out (when pre-orders open)? I really don't want to miss out on this case.
gwertheim
938
1,555
We will let you know when the orders go live, but I highly doubt we will know the minute the video comes out. I will talk to @Wahaha360 about timing
Mahjund
23
If I am not mistaken, it's gen 3. Wouldn't make a difference right now until the GPU's use gen 4 too
i think the Dan A4 4.1 has a PCI Gen 4.0 , and some Amd card has issues with Gen 3.0 like RX5500 XT so maybe in the near Future it will be a must have with the Ampere and RDNA 2.0 .
Sebbie
47
28
[/QUOTE]
thanks for the reply, thats what i needed to hear!
