    Votes: 116 24.6%
    Votes: 356 75.4%
  • Total voters
    472
MattyKHZ
72
21
Is there any chance of knowing HxWXD restriction for GPU in both 2 slot and 3 slot mode as starting to get pieces together and this would be handy to know?
Have asked multiple times but no answer.
Reactions: 0x3F2D
0x3F2D
37
29
Two slot gpus are at most 42mm thick. Based on some photos there is not much space for thicker cards in the two slot configuration. Maximal length is 315mm. Max Height is a good question but should not be that much of an issue as you have plenty of room above the gpu.
My problem is that GPU with waterblock + 19/13mm right-angle fittings are thicker than 42mm... :/
PBJ
358
546
That information will most likely be available at or shortly before launch. In the meantime, check out Optimum Tech’s preview of Prototype 1, he talks a bit about GPU compatibility
I’m guessing there’s maybe 2-3 people working on this project so they’re most likely focusing on getting every little detail ready (manufacturing, website, pictures, etc.).
I think we’ve all gotten a little impatient at times, but remember if they spend their time completing the case instead of answering all of our questions (and there have been many), we will get it sooner!
MattyKHZ
72
21
Thanks and appreciated.
guess if anything the longer I wait hopefully GPU will be more affordable. Would just be nice to know which 5700XT would fit so I can watch on eBay etc and use discounts if 10-20%. Black Friday Is also just round the corner.........
1st upgrade in 10 years and needed. Have memory, psi and cpu already, just need case, gpu, mb and cooling.
hopefully B550 will be announced soon or it’s looking like the gigabyte mb for me.
Mahjund
23
it's almost here and Looks Great , but i wonder how this case will fit 240 mm radiator (25mm) ?
- Motherboard 170mm + 15mm slim fan + 25mm radiator thickness = 210mm which is the height of case , what about the top and bottom panels thickness
and space for PCI Riser and maybe a space between the fan and motherboard , or did they calculate the volume based on internal dimensions ?
pwnedundies
199
356
Case looks great.
For those looking there are a few Lt240s on overclockers.co.uk and they are 10% off atm. Should come to around $100 shipped to the US.
Aguda33
107
187
Looking great despite the problems. Hang in there, you are almost there. I am sure a lot of us are patiently waiting.
Reactions: PBJ
PBJ
358
546
Update 2019-10-25 : looks stunning, but they messed up the anodizing on most parts, need to redo ?.
Some days you just want to cry, need to send most panels back because the anodizing has problems.
I can’t imagine how frustrating that might be. On the other hand, I’m happy because of your high standards
Reactions: Aguda33
