    Votes: 116 24.6%
    Votes: 356 75.4%
  • Total voters
    472
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
Thank you for the update,
I was hoping you could explain the GPU clearance difference between the current model and the upcoming model.
How much space is behind the mobo to the mesh side panel?
Thank you
-Leo
The minimum space between GPU fans and Steel Mesh Side Panel is 4mm, if you space the GPU away from the Side Panel, obvious you get more clearance.
PKAWA
490
488
2021-05-25: T1 V1.5 Progress​
Since there are some major changes, this update will be called V1.5.
Confirmed Update:
- Still less than 10L
- T1 V1.5 Unibody Front edition, USD160-210, available in US, UK, AU, DE, CN *only
- T1 V1.5 Two Tone Front edition, USD220-260, availability similar to V1.1
- Support both ROG 30XX and MSI Gaming X Trio 30XX
- Add PCIe 4.0 Riser option
- Support Deep Mini-ITX Support (ROMED4ID-2T)
- Support 46mm under the mobo for Radiator + Fan:
  • 20.5mm TX240 radiator + *dual 25mm thick fans
  • 27 or 30mm thick radiator + *dual 15mm slim fans
  • 27 or 30mm thick radiator + *single 25mm thick fan and single 15mm fan
- Support *dual TX240 240mm radiator setup, with 48mm CPU cooler height left for Pump & Res CPU Block
- Support 1.25, 1.50, 1.75, 2, 2.25, 2.50, 2.75, 3, 3.25 GPU Slots for more GPU vs CPU space allocation possibilities
- Add *new Tempered Glass Air Flow Side Panel
- Add Vertical Kit Accessory option
- Add Handle Kit Accessory option
- Official Instruction Manual and Assembly Video (YouTube)
- Remove T1 SFX Power Supply Flip Bracket (doesn't make meaningful difference in thermals)
Pending Update:
- Collapsible or Removable Headphone Stand
- Aluminum Mesh Side Panels
- NCASE M1 Layout Kit (include Notuca C14S Air Cooler Kit)
- Mini-DTX Support (Asus Crosshair VIII Impact, requires NCASE M1 Layout Kit)
- Freeflow Louvre Side Panels.
- EDC Slim Backpack Kit
How does it compare to T1 V1.1 *IMO
- For People looking for a cheaper option
- For People looking for air cooled setup without riser (5950X on Noctua C14S + 3080TI)
- For People looking for ROG 30XX and MSI Gaming X Trio 30XX support
Current *estimated release date mid August 2021 (release dates are always subject to change due to human malware & other uncertainties).
Can't wait to order one via your priority invitation mail.
NurseLeo
30
Hi Wahaha360, thanks for your reply but I was asking if the gpu compartment is getting any additional clearance? As shown here, is the marked space changing?
DrHudacris
918
1,720
Based on slot spacing, I would posit that space can be adjusted anywhere from 25mm to 65mm.
KamikazePlatypus
24
Confirmed Update:
Pending Update:
Also, you mentioned 5950X on Noctua C14S + 3080TI. Have you done or plan on testing this setup to compare performance and thermals with the traditional EK 240mm AIO + aircooled 3080/80Ti/90 setup? Myself and I'm sure others are planning the same build, so it would be nice to know which option is better.
tinyitx
2,279
2,338
Pending Update:
2 questions regarding the above:-
a. can you explain in a little bit more details about this air flow TG side panel? Do you mean, the TG side panel has perforations to assist air flow?
b. with this M1 Layout Kit installed, what is the max clearance for a tower air cooler? C14S, with the fan on top, is 142mm tall. So, 142mm has to be the minimum?
Reactions: N9neBreak3r
descuder
Hey, really excited about the 1.5 update post! Are there any hard numbers yet for CPU / GPU height clearance at each GPU slot increment (1.25 - 3.25)?
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
can you share why? if it's available for CN can I sneak in for VN?
Testing new shipping method, the shipping company limits to certain countries.
Can Canada be considered part of the US?
We are trying to warehouse in US to ship from US, but it's limited to what the shipping company can offer, and CA is not among our options at the moment.
We were always the crazy neighbor down south, you sure you want to 🤣
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
Are you still doing priority for people who cancelled their early 2021 T1 orders?
yes
Check 5950X on Noctua C14S + 3080/3090 in NCASE M1, you can compare to EK 240 no?
It's about air cooling's superior reliability and ease of install, not about pure performance.
Reactions: DrHudacris
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
Will share rendering when ready.
thelaughingman
1,413
1,566
understood, hope this method will work out. I'm asking more because I prefer the unibody front than the two-tone. just to confirm unibody means a single piece of alumnium right? not just that it's a single colour?
ellroy80
111
119
Optional. This new TG panel allows airflow, for cooling sake, so the cost really bit crazy because the yield is terrible, right now nearly 1 out 20 will succeed, so imagine breaking twenty glass panels to get one working, this is why is quite expensive.
Thanks wahaha. Just so it's clear for me then, the standard panels will be steel mesh, with the option for TG on one side, and you're looking into making aluminium (mesh?) a possibility?
