    Votes: 116 24.5%
    Votes: 357 75.5%
  • Total voters
    473
NurseLeo
30
@Wahaha360 Are the measurements for the T1 version 1.5 that are given in the opening post something I can count on?
If so I am ordering a TX240 because the chromax 25mm fans should hit the market this fall and that would be something I want to build.
TLDR:
- Still less than 10L, either 9.8 or 9.95L, currently 135x220x335mm
- 46mm under the mobo for Radiator + Fan, 20.5mm TX240 radiator + *dual 25mm thick fans, 27 or 30mm thick radiator + *dual 15mm slim fans
- Support dual 240mm radiator setup, with 48mm CPU cooler height left for Pump & Res combo
- Will support both ROG 30XX and MSI Gaming X Trio 30XX, debating MSI Suprim X 30XX support, it's 13mm longer and will push volume over 10L
- Support 1.25, 1.50, 1.75, 2, 2.25, 2.50, 2.75, 3, 3.25 GPU Slots for more GPU vs CPU space allocation possibilitie
The 46mm under the motherboard. Is that in the 2 slot configuration? I do not see how you can fit a tx240, 25mm fans and a gpu with only 46mm.
Am I missing something?
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
Space below the motherboard doesn't interfere with the GPU at all, so the 46mm is for 21mm of radiator + 25mm of fan.
Reactions: DrHudacris
Van0
129
166
I'm not sure if this is allowed here, so please remove my post if so, but I've decided to stick with my Meshlicious and will be selling my Formd T1. For collection only in London at the moment, though I'll put it up for UK delivery if no one is available. I'm not looking to make a profit at all, just sell it as well as a 240mm rad, DC-LT pump and noctua fans as a bundle at cost price. £361.61 is the total price. PM me for details and break down of cost / items. Additionally I have a Hanjiang 17mm rad if anyone is interested with 2 x scythe slim fans for £53.
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
2021-05-25: T1 V1.5 Progress​
Since there are some major changes, this update will be called V1.5.
Confirmed Update:
- T1 V1.5 Unibody Front edition, USD160-210, available in US, UK, AU, DE, CN *only
- T1 V1.5 Two Tone Front edition, USD220-260, availability similar to V1.1
- Support both ROG 30XX and MSI Gaming X Trio 30XX
- Add PCIe 4.0 Riser option
- Support Deep Mini-ITX Support (ROMED4ID-2T)
- Support 46mm under the mobo for Radiator + Fan:
  • 20.5mm TX240 radiator + *dual 25mm thick fans
  • 27 or 30mm thick radiator + *dual 15mm slim fans
  • 27 or 30mm thick radiator + *single 25mm thick fan and single 15mm fan
- Support *dual TX240 240mm radiator setup, with 48mm CPU cooler height left for Pump & Res CPU Block
- Support 1.25, 1.50, 1.75, 2, 2.25, 2.50, 2.75, 3, 3.25 GPU Slots for more GPU vs CPU space allocation possibilities
- Add *new Tempered Glass Air Flow Side Panel
- Add Vertical Kit Accessory option
- Add Handle Kit Accessory option
- Official Instruction Manual and Assembly Video (YouTube)
- Remove T1 SFX Power Supply Flip Bracket (doesn't make meaningful difference in thermals)
Pending Update:
- Collapsible or Removable Headphone Stand
- Aluminum Mesh Side Panels
- NCASE M1 Layout Kit (include Notuca C14S Air Cooler Kit)
- Mini-DTX Support (Asus Crosshair VIII Impact, requires NCASE M1 Layout Kit)
- Freeflow Louvre Side Panels.
- EDC Slim Backpack Kit
How does it compare to T1 V1.1 *IMO
- For People looking for a cheaper option
- For People looking for air cooled setup without riser (5950X on Noctua C14S + 3080TI)
- For People looking for ROG 30XX and MSI Gaming X Trio 30XX support
Current *estimated release date mid August 2021 (release dates are always subject to change due to human malware & other uncertainties).
jpark113
Confirmed Update:
Pending Update:
Would it be possible to grab a v1.1 before this? I prefer the smaller size (if i understood correcty)
Reactions: 2drcDhLb
NurseLeo
30
Confirmed Update:
Pending Update:
Thank you for the update,
I was hoping you could explain the GPU clearance difference between the current model and the upcoming model.
How much space is behind the mobo to the mesh side panel?
Thank you
-Leo
shopan
is the - Add Vertical Kit Accessory option compatible with V1.1? also will the pcie4.0 riser available separately and compatible with V1.1? thanks
Stig023
Confirmed Update:
Pending Update:
Thanks for the transparency in the update process! I'd be very interested to hear about the NCase m1 layout kit, seeing as I already own an NH-C14s. I assume that this means a conventional layout without a riser?
staxxats
Would the formd v1.5 support 240mm EK AIO + 2x 25mm full size fans (such as the noctuas) which are a popular configuration option (instead of having to compromise with 15mm slim fans)?
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
Yes, waiting for some parts before we release.
Size difference between V1.1 and V1.5, visually no difference to the eye, just 3mm taller and 2mm wider, and 5mm deeper, you can’t tell the difference.
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
Is the tempered glass side panel an option or the default?
Optional. This new TG panel allows airflow, for cooling sake, so the cost really bit crazy because the yield is terrible, right now nearly 1 out 20 will succeed, so imagine breaking twenty glass panels to get one working, this is why is quite expensive.
