    Votes: 116 24.6%
    Votes: 356 75.4%
  • Total voters
    472
dream3
78
Latest batch here came with mesh sides panels slightly bent in different areas. Really not satisfied with this level of finish. What is the best way to contact them for replacement?
Reactions: odeniz
hetvler
204
153
Lol ! I made the same choice.
and the 5800x has almost the same power consumption !!!
Well actually after looking at benchmarks i think i was getting suckered by workloads I'll never actually utilize. I've opted for the 5600x now haha. Seems the be more than plenty for 1440p gaming and making the occasional meme in photoshop.
PKAWA
490
488
The chip... and the box! ;)
Formd T1 in black and silver for the december batch
Dynavox silver case feet
Asus x570-i
Nouvolo Aquanaut
EK DDC 3.2 pwm + heatsink
G.skill 32gb ram cl16 3600mhz
Coolworld 240mm radiator
2 Adata 2tb nvme m.2 ssd's
Corsair SF750
AMD 5900x
2 slim noctua fans because I currently have one, and the other one is making to much of a racket for my taste.
New power cable that will allow me to use the port on the back to connect the rad permanently, and give me more space for copper tubing.
IF i can manage to make it work, but currently recovering from corona so can't do anything atm.
And I'm planning on buying the 6900xt to go with it.
Reactions: DrHudacris
Mao_Setzer
37
71
Asus x570-i
Nouvolo Aquanaut
Corsair SF750
AMD 5900x
Curious to see the final result with all those parts :) PS: you didn't choose or have a GPU ?
Get well, Stay safe and always wash your hands !!
Reactions: PKAWA
PKAWA
490
488
@PKAWA I meant which option did you pick for the low profile power cable?
I'm going with the cable that's also used in the acat x1
I'll be using the forward version so that the cables will be routed towards the gpu.
But with a different connection for the backplate of the case
PKAWA
490
488
Will the T1 be updated to accommodate longer RTX cards?
Ofcourse not. Basically everything would need to be made longer so that is such a high cost that they'll never do that.
And the P1 is already on the table, so i think that would be your best bet.
I think that will take another year though.
ciaran clare
72
64
Yes, but i also bought a drill bit so it will be alright. Just need to be careful drilling the hole in the gpu.
I had troubles drilling through my GPU, after drilling through the PCB and the heat sink i tried to boot my card.... it refused to turn on, i have a feeling drilling through the heat sink meant my GPU thermal throttled and doesn't power on. If your water cooling though this shouldn't matter and you can just drill straight through the PCB without any issues.
  • Haha
Reactions: ten13th and PKAWA
