    Votes: 116 24.6%
    Votes: 356 75.4%
  • Total voters
    472
thelaughingman
1,413
1,566
The Aquanaut fits very nicely into the T1. I'm currently bleeding the loop but I definitely prefer it to the Apogee.
I think I might be able to get it to work in the GPU 3 slot mode...
I'm gonna test it in 3 slot mode tonight and tomorrow, just dry testing because I don't have all the stuff with me physically. If it's too tall then Fr33flow is my only hope ?
Reactions: Gerold and Goatee
Luke NK
126
116
That's on the motherboard vendors, has less to do with the case.
The rear I/O shield hitting the heat pipe on L12S is the problem that should be fixed. Other solutions are bandaids to a gun wound.
So I don't plan to make changes to the case - I already told ROG and Noctua to work it out.
ah thanks. I thought it was a design flaw, good to know there might be future motherboards that probably won't have this problem
dehedehe
The IO shield issue prevents L12S from being installed on the ASUS mobo in horizontal heat pipe orientation (bend to rear).
Workaround by reddit user u/catesnake: imgur.com/gallery/yM50rhD
L12S and T1 case compatibility is a separate thing, caused by multiple factors: L12S size, CPU socket placements on different mobos, and T1 side beam location.
The MB side beam overhangs the mobo edge section where you find CPU 8pin connector and fan headers. Reducing the airspace limit of this section to about 65mm in 2 slot GPU mode.
For AM4 mobos, with T1 flipped (fans on top), L12S in horizontal or pointing up (bend to pcie) orientations won't fit because the fins, which requries 70mm clearance, also overhangs that section.
If you are ok with not installing the MB side beam, there is a workaround.
www.reddit.com/r/FormD/comments/iaccvo/my_solution_for_having_the_nhl12s_in_the_right/
In order to have both the MB side beam installed and L12S fit in horizontal orientation, the MB side beam needs to have the option to be moved up. My rough estimate is ~16mm+ to cover all current AM4 mobos. However that isn't a simple change.
The bracket for mobo standoff and riser holder is currently coupled to the GPU side beam for structure rigidity. The GPU side beam has to remain where it is. If it moves up in sync with the MB side beam then the clearance issue will still be there. Now you have the two side beams positioned asymetrically and that will have flow on impact to case fan mounting.
Personally, in the beginning, I wanted to do an optimal full air cooled build in T1 using L12S. Given that 2 slot high end GPU is almost non-existent, I've accepted 3 slot mode and I will use AIO to cool the CPU.
Reactions: Merry Monkey
Luke NK
126
116
Thanks. I too want to get over these issues and use an AIO instead, but I will be moving around hopefully next year and AIO + air travel might be a problem
Ashenfall
57
79
lots of people have discussed AIO air travel concerns in the subreddit and plenty of people have reported no problems
That said...I can't remember if those who said no problems were travelling within US only. Internationally might be a different story
same with me. Wanted air cooled build, post Ampere launch had to change my plans and go AIO
Reactions: Madhawk1995
Navic
587
1,341
To be honest, I’m a little worried about the 3080 GPU exhaust limiting the radiator effectiveness.
Why would you be? It would be just like any other air cooled GPU exhausting the hot air into the case and then the radiator.
If anything the FE design is better for the radiator as some of the heat is exhausted out the back of the card, instead of all of the heat from the GPU going into the case and radiator like the more common AIB coolers.
Luke NK
126
116
I'm not from the US. I only need one person saying he couldn't travel with an AIO for AIO to become a concern to me.
Navic
587
1,341
I think Wahaha has traveled from the US to China with his T1 and an AIO, so you should be fine. If it's in a closed loop, then there isn't a whole lot they can do.
robojim
254
222
All the testing I've seen indicates the fan on the pcie side exhausts a great deal of air straight out the back, like a much better version of a blower card and that concerns of the rear fan choking off other components is greatly exaggerated. I don't think the FE will have much trouble in a T1 that has good exhaust set up.
Luke NK
126
116
Some people reported having issues. I remember one guy traveling from Europe had to call a relative to come pick his SFF because they wouldn't let him board with an AIO in it. And you can't carry on tools either so you can't improvise and disassemble the case if this happens.
Since I only plan to build with ryzen x600 noctua nh-l12s should be able to handle it good enough, no need to run risks
Reactions: DrHudacris
x111
114
45
but can you just drain liquid ?
and maybe telling nothing about your computer ?
that is very important aspect how to go around their regulations.
Luke NK
126
116
Yeah I thought of that but going around draining a custom loop for a ryzen 4600/5600 seems too much trouble. This is something I might be more interested in doing once I upgrade to ryzen 7 and with a freeflo or aquanaut pump in the future, I don't quite trust alphacool dc-lt
Navic
587
1,341
You can't drain the liquid from an AIO, it is a closed loop. If you open it, you're most likely going to destroy it.
And not telling them about the computer is an option, but if they know what the AIO is, then you might not be in a good spot.
Paul_the_Octopus
40
28
Anyone knows how long it takes for the formd team to correct/update a shipping address? I've sent them a mail with the updated shipping address, but i haven't heard from them yet.
max31092
76
45
Took them 10h for my adress. But ther'll be variation according to when you wrote the message. By the way I just used the contact-formular.
Paul_the_Octopus
40
28
Thanks. Contacted them about 10 h ago, and I've use both the contact form and email, I guess i just have to wait a bit more. Were you notified when they updated your address?
