    Votes: 116 24.6%
    Votes: 356 75.4%
  • Total voters
    472
TSOF
113
181
Short enough to fit in almost any SFF case out there. The main problem is the height of the waterblocks with the terminals, because the terminals might make certain blocks (like the ones for the 3090) too tall to fit.
I think the 3090 pcb is the same as the 3080, it’s just the cooler that’s bigger.
PKAWA
490
488
Don't need cnc with alu... accurate hand filing.
Aluminium is soft as butter.
Yeah but it's not gonna look as good.
Those cards have massive shrouds on them. How long is the card with a custom water block? That's the question...
I don't think that's an option in the T1. Cooling a 350w card and CPU with one 240mm rad?
Reactions: ellroy80
BOGLOAD
25
I recommend staying away from the H60, as there is absolutely no control for the pump or the lighting, and it requires SATA power, which other AIOs do not. Look into the EK 120 d-rgb or CoolerMaster ML120, both will fit in 3 slot mode, though the EK will make the side panel bulge out slightly, but it is not very noticeable unless you are really looking for it.
Thanks for that. Looks like the 3080 will fit in a 2-slot configuration no problems. Would the EK 120 still bulge in that config? Or does it bulge regardless of 2/3 slot configuration? The CM v2 unit seems to require molex power regardless for the RGB portion (eww why in 2020).
Madhawk1995
84
62
Yeah I saw this last night, but again, it’s a 2.2 slot it seems from information gathered on reddit. Without the measurement in mm, it might be problematic inside the T1?
No problems in 3 slot mode. Most of you guys are good. Most 3090's fit in the T1. Just get something below 312.4mm in length like a Strix 3090 2.9 slot thick GPU or even evga FTW3 3090 2.75 slot GPU. For the kids trying to air cool and keep the case in 2 slot mode. Good luck. Just buy an aio or run an axp 90 full copper for your 6-8 core zen cpu.
gwertheim
938
1,555
The FTW cards have issues with height, it's a mm or two too high
Reactions: Madhawk1995
Nhilros
Well my intention was to be in 2 slot mode and air cool cpu with NH-L12S, with the risers on PSU so that the founders edition air exhaust between GPU and PSU and get the top fans to exhaust ?
haha yes good luck to me I guess.
ManaNeko
43
49
It seems there is a tiny different Eisbaer LT from Alphacool, with the coldplate Nickel plated?
...Huh.
I wonder if that AIO would fit the DAN-A4. I doubt it, plus not having 90° rotary fittings is a no-go.
Navic
587
1,341
All the EK aios bulge in 3 slot mode, but not in 2 slot mode. And if the CM requires molex for just the RGB and not the pump, then I see that as a win!
Reactions: BOGLOAD
