Fitting a full size GTX 750 Ti into a Streacom F7C
aquelito
Piccolo PC
Feb 16, 2016
948
1,116
Thanks to both of you for your input.
I'm pretty confident that tightening the screws will solve the issue.
As for the fans, I checked during the test the airflow going through the radiator and it seemed fine to me.
In the final build, the case panel will act as a shroud, given there is almost no clearance between the top edge of the fans and the top panel.
I will certainly have to make side shrouds though.
I also took the opportunity to test the PicoBox X7 500, in a dual brick configuration.
It emitted a faint coil whine with the GTX 970. No coil whine the HDPLEX 250W :)
Which means I'll have to buy a 70 € Dell brick...
Let's talk about all that in september ! Vacations for now :)
aquelito
Piccolo PC
Feb 16, 2016
948
1,116
Back with my faithfull 750 Ti for now. Good news is that I have now two intake 92 mm fans and I can run my 750 Ti passive.
Temps stabilise at 80° after 1h of Engine Valley bench.
When rendering or gaming, max temps reach 65/70°.
aquelito
Piccolo PC
Feb 16, 2016
948
1,116
Last question :
The front plate machined to hold the Asetek pump also acts as a "giant" heatsink, as it is in contact with the memory chips thermal pads.
However, is it going to improve the cooling further more to glue heatsinks directly on the front plate, using thermal glue ?
It could also slow down the heat dissipation, because of the extra alumnium layer.
What do you think ?
Reactions: Ceros_X
