Thank you, stay safe
Daniel
For what it's worth, I think this top panel with the power button really makes the case look much better than with the slotted vents as it's more consistant with the entire case.
It is also great to see that 25mm fans can be used with a 2 slot GPU it seems...
It also seems there is the potential for a dual 240 radiator setup if the GPU is also water cooled using an LT240 + 25mm thick fans and a TX240 with 15mm fans...would be really good for cooling potential.
