AgreeI think the IO cutouts on the old renders make it looks a little outdated and cheap.
Optimum already is using this case and give feedback that's why there are so many changes before go live@dondan Hi Dan, I'm not sure if this has been discussed or not, but have you thought of giving a "finished" sample to Optimum Tech and others(without them making a video) before the production kicks in? I assume there is going to be V2, V3 and so on of this case, and wondered if Optimum got an exampe before the production, then he'll might have some feedback directly to you?
I really like the top cover with the transversal cut (like in your renderings) instead of the classic hole pattern solution, i guess you have to increase the thickness of the sheet metal to mantain the same rigidity right?
Looks like the top panel would need to be a lot thicker for the slotted vents to be rigid enough.
Although I preferred the slots in the rending, I like the holes better in the actual metal.
