Can you share your analyse so far?
Sorry for the rather late response as I really have not done much comparison. One reason is that there is very little info of the M1EVO and C4-SFX has only been reviewed by one website.
Anyway, what I have now is:-
1. Z13 14.6L 340x170x255 (14.6L), 138mm cooler, 315mm GPU
2. Acat x2 328x164x264 (14.2L), 138mm cooler, 314mm GPU
3. M1EVO 366x160x256 (14.99L) , 135mm cooler, 360mm GPU
4. C4-SFX 350x166x274 (14.7L), 145mm cooler, 336mm GPU
1 and 2 are traditional layout.
3 and 4 have inverted layout.
1. COOJ Z13
pros
‧screwless CNC all aluminium unibody enclosure (ie no joint/gap due to side panels)
‧v2 has improved upon v1
‧material and construction quality is probably best in this list.
‧USD 232 (Taobao price) + shipping is cheap as I reside in China
‧max 6 fans supported
cons
‧not max compatibility with longer GPUs
‧max GPU thickness is 65mm
[Edited on 2023-05-11] bad customer service, (1) breaking promised dates of availability and (2) not replying to Taobao/QQ messages. This could be a real deal breaker! How unfortunate!
Ref video review:-
2. Acat x2
pros
‧USD 188 (Taobao price) + shipping is cheap to me in China
‧max 4 fans
‧CNC enclosure with no visible external screws
cons
‧PSU connection uses uncommon plug
Ref video review:-
万年果粉装机初体验|Acat X2|全铝A4机箱真能塞我的装机配置清单:主板:华擎Z690M-ITXCPU: Intel 12代酷睿i5-12600k显卡:七彩虹RTX3070TI Customization OC 8G电源:长城850W金牌全模组(不推荐)内存:英睿达铂胜白甲8G DDR4 *2硬盘:西部数据WD SN770 1TB SSD固态硬盘散热:利民Frozen Magic冰封幻境240, 视频播放量 11574、弹幕量 18、点赞数 188、投硬币枚数 69、收藏人数 83、转发人数 22, 视频作者 麦克斯MAXD, 作者简介 数码攻略|智能家居|家庭影音...
www.bilibili.com
同类视频:这台‘银·风K77’让我装三千遍都不会腻 BV1aE411y7B7水冷快乐盒L装机案例 BV1EE411j7rC因为机箱工差 我无奈延长交付时间——老李R1S BV1Ga4y1i7Jf为了省钱上魔龙 只好Z270魔改上九代了 BV11z4y197Fe符合这些条件3700X也能用原装散热器 BV1N5411e7RF下压应对十代10700的最佳机箱——G-A4L改版 BV14Z4y1u7Rk, 视频播放量 18335、弹幕量 5、点赞数 138、投硬币枚数 31、收藏人数 65、转发人数 14, 视频作者 浮点工作室, 作者简介...
www.bilibili.com
3. NCase M1EVO
pros
‧longest GPU
‧Price starts at USD 200, lower than the 2 above. However, the key word is ''starts'', which means the price will go up with options/accessories/configurations. No details yet. Probably the cheapest of all 4.
cons
(Really cannot say much as this case is least known among the four.)
4. Dan C4-SFX
pros
‧tallest air cooler 145mm
‧USD 220
‧5 fans
cons
‧one minor concern is the fitting, particularly the side panels onto the main body. From various pics and OT's review, I notice the side panels seem to 'bulge' a tiny bit at the mid section, instead of totally flushed. See pic below for example.
‧have to order from Newegg and not sure about the shipping cost
Review video:-
Optimium Tech
I will build 1 system for a family member and then most likely another one for myself.
These 2 builds will both be ''all-air-cooling'' builds and so I have not considered very much the watercooling capability of the cases.
The air cooler in mind is Thermalright Silver Soul 135 which can be fitted into all these 4 cases.
I reckon, if one wants max compatibility+highest end components+ max out every single c internal volume, 3 and 4 might be better?
So far, I am thinking I will buy one between 1 and 2, and another case between 3 and 4.
