DAN C4-SFX
Justinian
Is the optimal choice of CPU cooler and case fans, if a 4080 FE is installed at the top (inverted)? Presumably not enough space to have 2xfans above the video card.
1x92mm pull air in to case
Noctua D12L with 1xfan pull air back to front
1x140mm - push air out of case
Tesserae
Update:
Timeline:
- The C4-SFX Batch1 production will be done on 22th march 2023
- container shipping to resellers will be 7 weeks
- local custom processing and shop arrival will be 1-2 weeks
The C4-SFX will be available mid may 2023 in the following shops:
EUROPE: Caseking and connected shops like (JIMMS.FI,GLOBALDATA.PT,Mindfactory s.o.
INTERNATIONAL: OverclockersUK and connected shops like (ComputerOrbit s.o,.)
JAPAN: Dirac
AUSTRALIA: PcCaseGear * should be available some weeks later
Direct US selling: I was not able to get a reseller in the US so I created myself a Newegg account today. I will test newegg with a smaller batches of cases in Q3 2023 on the offical DAN Cases newegg shop.
Update:
Timeline:
JAPAN: Dirac
Hey Daniel,
I tried to email you, but it returned as undelivarable.
I actually started an SFF PC company a few months ago, and would love to become a reseller. I actually originally became interested in SFF PCs back when I learned about the A4-SFX and bought one about 4 years ago. I would appreciate the discussion to see if we can work together. You can email me at admin@tesserae.io
Thanks,
proficide
23
Hey Daniel,
Thanks,
Are you US based?
ScottXGTR
Are any retailers doing preorders? I'd like to get my hands on one as soon as possible. My nitro 7900xtx does not fit my current case but looks like it will be right at home in a c4
Arboreal
727
741
Looks like it on the Optimum Tech review, he even squeezed in 2 120mm slim fans on top. Result!
Justinian
I wonder how impactful a 92mm rear fan would actually be, or spend the money elsewhere on the build 🤨 Hopefully one of the YT channels will test this.
sparkymark75
Couple of questions on AIO support. Would the EK AIO with Phanteks T30 fans fit? I think that would be 57mm thickness.
Have you tried intake v exhaust for the AIO fans setup? If so, which was the better configuration?
dondan
DAN Cases
1,871
7,946
Here is the thermal test:
