I'm glad that we are back to the initial C4 layout and design again. It is a beautiful design, and I got the impression that the design is mostly complete by now and waiting for finalization to go into funding and eventually production in H1 2018. I'm planning and building my new PC to fit into the C4 when it finally arrives and I would have been bummed out if the original C4 had been further delayed or even replaced
So I found a solution for the classical C4-SFX design to solve the attaching problem with slide in mechanism without adding many millimeters to the case.
That's interesting. Several weeks ago I wanted to ask you if a classic sliding mechanic could be an option to solve the problem, but then family matters got into the way and I forgot about the C4 and my new PC for a while. Is there also a chance to integrate the window into a sliding aluminium panel? While I will very likely prefer the perforated side panel anyway, it might be interesting to have window option without "nubby" thumb screws.
Also, where are the drive mounts? Behind the front panel? Brackets underneath the PSU?
As bilibili1 just pointed out, there are other similar designs to the C4 that may result in more competition which the A4-SFX didn't really have until more recently.
Those alternatives aren't widely and easily available, especially not in Europe. Not to mention that many people don't like to order "around three corners" and from other continents. The C4 however might be available through Caseking, a renowned only shop for PC cases and components that delivers to entire EU (other leading online retailers have the A4 too).
The only real and readily available competition over here is the Raijintek Ophion (Evo), and that's a serious competition despite the design flaws. But the Ophion doesn't have support for three slot video-cards, it doesn't have the quality, it is not space efficient, and it doesn't have vented side panels. Plus, there are more "skyscrapers" than there are Ophions. The C4 will do as fine as one can expect from a prices small production "craft SFF" case.
@omega24
That wouldn't make a real difference. The bigger problem with a sandwich design is that you have to settle for a video card size. A layout for three-slot coolers would waste space (that might have to be taken from the mainboard compartment and the CPU cooler height), a two-slot layout would be more space efficient but limit compatibility for high-end video cards. A layered layout like in the C4 allows for better compatibility with high-end components, but limits the use of air-cooler for the CPU and almost requires to opt for an AiO.
Then again in a layered layout like the Ophion the user decide to cool the GPU instead of the CPU with an AiO. Decisions, decisions. I think that a sandwich layout would be smarter, but it would liekly force me to get an AiO for the high-end Radeon that I want to use (therefore I hope that Dan won't listen to me and just finalize the C4).
