DAN A4-SFX v4.1
The6A
62
35
Fit yes, but you have no venting holes and mount points.
Thehack
Creator
Mar 6, 2016
2,818
3,675
J-hackcompany.com
Just wanted to share here in this thread: I made a 3d printed adapter that allows you to use 120mm fans with the Cyrorig C7.
When paired with a Raijintek 120mm slim, or a Scythe 120mm slim (direct order for the PWM version), the total height is 45 or 44 mm respectively.
Should be useful if someone wants a slightly more powerful cooler (while waiting for Dan's own cooler :) ). The extra 3-4mm should help it against turbulence.
Link to Thread
dondan
DAN Cases
1,966
8,288
Update:
Survey:
Here is the result of the survey with 280 votes in total:
As you can see 48% of the participants vote for the DAN cutout so it will be available on the Kickstarter kampaign.
Kickstarter
Currently I am in the process of creating the Kickstarter campaign for the A4-SFX v2. As you maybe know my english isn't the best so I need your help.
If you are a native english speaker and you have skills in writing and grammar please please contact me over the HardForum message system and help me proofreading the text for the campaign.
New Pictures
Here are some of the new pictures from the A4-SFX v2 with black background for my website:
One preview with white background:
With best regards
Daniel Hansen
Arboreal
850
851
snip...
Kickstarter
Daniel Hansen
Daniel, I'm not on [H] but do look at it from time to time. I would be happy to help with the writing if you need.
I can't remember if you posted on Bit-Tech, my other online 'home'? I have the same user name, and you can PM there.
BTW, brilliant work again; you really have got it right with eth A4-SFX, and then taken it to a new level.
ondert
348
163
Probably this will be the best build among the mini pc cases. Full length blower gpu and AIO cpu cooler in just 7 liters. It was all I was wondering. I'll be definitely waiting for the Kickstarter campaign.
Btw, I have an SFX-L psu, will it fit in this case?
WillBlackstone
43
Yes, although cables will be a bit more difficult but doable
grumpyrobin
260
190
AIO cooler? I keep searching the thread but I can't find info on where it would fit
Edit: nvm, it's the Asetek 92mm AIO
Edit:
Dan,
Do you have a temp comparison between DAN HSLP-48 and Asetek 92mm AIO yet?
tomternal
UPDATE:
The Countdown has started...(subscription mail will be send out tomorrow)
Is the V2 case going to be another kickstarter campaign or are they going to be available through the retailers for immediate purchase?
EDIT: nvm I found the earlier post!
Bench
May 23, 2017
Sorry to hijack the thread, don't suppose anyone has a spare or used Dan Case a4-sfx that they are willing to sell me?, I would back the kickstarter campaign but I go to university in a couple of months and need a case small enough to fit into a backpack to take on a train.
KMPKT
3,382
5,936
I think posting in the buy/sell forum would be a more appropriate and visible place to post your request (it gets a big colourful tag and everything!)
