Production cases: SLM1m/ SLM1 4L/ SLM2 5.7L by Custom_MOD
sergiiua
CustomMOD
Jan 11, 2017
1,135
2,027
www.custom-mod.com
Party 7 was sent.
Party 8 is still in the process. The plant still has not sent the details. They promised to send it before the holidays. We apologize for the delay.
Party 12 will be closed early on January 15.
Instran0
526
107
case SLIM itx 4.5L rev.5 prototype PHOTO ALBUM (is not yet available for order. testing)
Specs:
- Volume: 4.5L (325mm x 185mm x 75mm)
- Weight 1.5kg
- Production: ESI METAL factory (video), swiss solutions «Bystronic»
- The CPU faces up and the GPU faces up
- Material: 1.5mm Aluminium, Powder Coating
- GPU: length <178mm, height <130mm (Giga 1080 Mini and MSI 1070 Aero ITX compatible)
- CPU Cooler: up to 50mm
- RAM: up to 50 mm
- Storage: M.2 only
- SSD/HDD: 1 x 2.5" 5-15mm or 1 x 3.5"HDD
- PSU: external G-Unique pico 400W or G-Unique 300watts HP 80plus platinum internal module + pico type A 300W
- PCIe riser: LiHeat 350mm B.type
i've tested this prototype.
in order for cooling to work properly, it requires a CPU fan with a copper heatsink.
therefore, customers will need to request a modified version, with a height of 73mm.
sergiiua
CustomMOD
Jan 11, 2017
1,135
2,027
www.custom-mod.com
therefore, customers will need to request a modified version, with a height of 80-82 mm.
but as the cooler Noctua L9i showed himself? he with copper tubes
Instran0
526
107
Noctua NH-L9i fails Prime95 and Furmark tests, when using newer CPUs.
a fan with copper heatpipes is needed for cooling.
those CPU coolers require a modified prototype, at a height of approximately 73mm.
sergiiua
CustomMOD
Jan 11, 2017
1,135
2,027
www.custom-mod.com
We are pleased to bring to your attention a new case! In the photo, the prototype and we have already planned some changes, namely:
1. Remove the ventilation hood from the front.
2. Add some mounting holes.
3. Make similar vent holes in the floor and back cover.
4. Add an internal partition separating the graphics card from the motherboard. (not exactly)
Perhaps you will tell me what needs to be changed.
case SLIM M2 8.1L prototype
Specs:
- Volume: 8.05L (330mm x 305mm x 80mm)
- Weight 1.8kg
- GPU: length <298mm, height <130mm < 42mm
- CPU Cooler: up to 58mm or aio radiator 120mm (Corsair H60 compatible) only SFX PSU and GPU to 170mm
- RAM: up to 60 mm
- Storage: M.2 and options below
1) HDD: 1 x 3.5" (it is possible to install the button in front and USB ports)
2) HDD: 1 x 3.5" and 2 x SSD/HDD: 1 x 2.5" (without USB ports, the back-up button)
3) SSD/HDD: 2 x 2.5" and FAN 80,92,120 x 25mm (it is possible to install the button in front and USB ports)
4) SSD/HDD: 4 x 2.5" and FAN 80 x 25mm (it is possible to install the button in front and USB ports)
5) SSD/HDD: 6 x 2.5" (without USB ports, the back-up button)
- PSU: SFX/SFX-L
sergiiua
CustomMOD
Jan 11, 2017
1,135
2,027
www.custom-mod.com
Case SLIM M2 is already available to the order. We have slightly reduced the size, having revised the location of the components.
- Volume: 7.6L (325mm x 305mm x 77mm)
- Price: $199 (Case -10%+ PCIe riser + Worldwide Shipping)
Instran0
526
107
we need 7.5L size.
will it work like this :
case SLIM M2 7.5L rev. 6.2
Specs:
- Volume: 7.5L ( 323.5 mm x 305 mm x 76 mm )
- Weight 1.8kg
- GPU: length <298mm, height <130mm <42mm
- CPU Cooler: up to 53mm or aio radiator 87mm (Asetek 545LC 92mm compatible) only SFX PSU and GPU to 170mm
- RAM: up to 60 mm
5) SSD/HDD: 6 x 2.5" (without USB ports, the back-up button)- PSU: SFX/SFX-L
- Payment method: PayPal
sergiiua
CustomMOD
Jan 11, 2017
1,135
2,027
www.custom-mod.com
we need 7.5L size.
Specs:
- Weight 1.8kg
- RAM: up to 60 mm
yes you can and so to do.
Instran0
526
107
Specs:
- Weight 1.5kg
- RAM: up to 55 mm
i tested the case.
it works.
sergiiua
CustomMOD
Jan 11, 2017
1,135
2,027
www.custom-mod.com
Hello friends!
For a long time we solved the problem of screws. We wanted to remove them from the prominent parts of the buildings. But we can not remove everything. But we can offer more beautiful screws. They are more expensive than ordinary ones.
They are screws made of aluminum with a hex screwdriver. Not everyone has this and this is a problem. We offer to supply a hexagonal wrench with 2 mm screws.
Such screws can be ordered in different colors, which will make your case more beautiful.
Write your opinion. For us it is very important!
