The project is completed! Jump to the second post for details!
I'm finally working on my custom SSF case and I want to put my 3D printer at good use. I've seen the very good project by @Thehack who designed the corners and the case is held together by the sides. @jottwehh instead went ballistic and 3D printed the whole frame (great project btw!).
My idea is to create a system of modular corners and frames for easy and fast prototyping, so that at the very end you can print or laser cut the sides of any material you want.
Being a super-noob I often make mistakes and miscalculate some distances. With a system like the one I have in mind you just need to re-print a couple of frames, not the whole case from scratch.
This is the very first prototype.
The frame is held to the corner with countersunk screws so the screw heads are flush on the plastic bit. Everything is covered by the side panel. For easy access the screw holes for the side panels should be threaded... or better use a threaded insert like one of these.
The side walls thickness is parametric (defaulted to 2mm) so I can change it to any value and the model is rebuilt accordingly.
So far the thing looks like this (the frame will of course be longer, that's just a quick test)
The whole cube is 32mm while just the corner is 25mm. It looks pretty darn good already even if printed at low res
Other than the outer frame I will also design a "plate" to hold the mini-itx motherboard and few other things (eg: PSU holder).
Suggestions? Ideas? Suggestions?
PS: I was not completely sure where to put this post... hope this is fine
