Cooling Cooling setup advice
Skripka
Cat-Dog Perch Manager
May 18, 2020
391
477
UNI Fan AL120 just launched with more static pressure at lower noise compare to the SL120 - this is what longer blades do for you I guess 😂 Once again I'm getting the urge to swap out the trusted A12x25s for these babies
Other than not being beige...the Noctuas have almost as high a flow rate at 6dBA less noise. Presuming Noctua's and LL's testing methodology are the same.
Dawelio
Awesomeness
503
427
The fan blades themselves are also 6% wider, which according to Lian Li is what makes them more powerful basically.
Personally I am waiting for the 140 version for my Z63 AIO in the Meshlicious.
Reactions: thelaughingman
2,201
2,215
Airflow and noise numbers are pretty much never comparable - there's no accepted standard for testing these things. Alrflow is often ballpark comparable, noise is a complete crapshoot. Pressure tends to be pretty comparable as well. But overall, reviews are always necessary.
