Hi, who knows what fans can I use with the D15 instead of the original ones?. I'm having trouble to determine it, because of the odd form from the originals ones, should I go for 120 mm or 140 mm? or neither since I'll have the issue anyway?.
I was thinking of using one or a pair of 140 mm industrial ones. I know is overkill and adds more noise, but since is an ITX case, might come handly for some more extreme scenarios, long renders, video conversion, long gaming sessions, etc. I'm not that bothered by noise under intensive use. The issue that motivates the need to change the original (great fans) is the following:
Due to the position of my Front Panel USB3 Typer A connector, I just can't install the original fan there, it will go way over the limit of height from my Lian li TU 150.
I've just received from lian Li a new front panel, great gesture, so disconnecting and not using the front USB3 isn't an option, more when I've tried to remove it, to see if I can root the cable differently in order to gain some space and it is stuck as hell, no way I'll break that hideous connector again.
I've attached a pic of what I'm talking about. Also I'm just guessing that a "normal" 120 mm or 140 mm will fit either, but it seems to me thatI'll have more space. What are your thoughts? thanks in advance!
