Prototype ContainerA A4- Aluminum case & Mirror stainless steel Case
WH-team
103
187
Amoy China
Hi everyone,
This is the A4 chassis I've recently redesigned.
This design is compatible with more flexible standard hardware.
In this project, I used a combination of materials including aluminum alloy, mirrored stainless steel, and acrylic.
The design of the front of the case is something I've been really happy with after a lot of recent tweaking.
I hope you all enjoy my design.
Container A specifications:
• 13.61 L volume with 356 x 239 x 160 mm outer dimensions
• A4 structure
• ATX power supply up to 140 mm//SFX power supply up to 120 mm
• Universal GPU Compatible with riser cable options//'BKB' ITX mother borad connect
• support for following motherboard sizes: mini-ITX,
• support for 335mm long triple slot graphic card, can switch in 3 slots//3.75 slots two models
• support for 240//280mm AIO radiators
• CPU coolers up to 70 mm//55 mm in height
• front USB-C gen3.2 port+2 x USB 2.0 port+ 2 x USB3.0 port
• Mirror stainless steel & anodized aluminum material
• The adjustable frame meets different hardware needs
• 4 kg weight
The case's model renderings​
This is a video I made with rendering, which gives you a clear look at the whole structure of the case​
https://www.bilibili.com/video/BV1G...eb&vd_source=7581fcc94f19530d9b4781174bba639e
https://www.bilibili.com/video/BV1J...eb&vd_source=7581fcc94f19530d9b4781174bba639e
Prototype from early September 2026​
I'm satisfied with the precision of the assembly​
The inner frame of the sample is black, but for the final version, I'll make it white like in the render.
Reactions: NinoPecorino
