Prototyping CONSOLE and CONSWOLE: entry level 2-slot and 3-slot console cases!
Retrias
23
I want to see the design of the biggest version first, since swapping to atx open alot of possibilities for me , even if I wouldnt use the rad space
Lemonsharks
Is it possible to mount 25mm fans on the top of the gpu in the 3 slot version of the case?
I have this setup for my GPU in the Node 202 and it really helps with the case temps with it pulling hot air out of the case and I think it would be great for the Console as well.
That or have the PCIe mount on the back of the Console a screwed in plate so that the user can reverse the orientation to have the GPU to face the 2 fans in the shroud and keep the ability to use the 3rd slot for some other PCIe expansion as well. I don't know how feasible that would be cost wise but that would be a great option to have for the case.
Definitely getting one on release, love this form factor :)
Reactions: KSliger
ac1617
Oct 24, 2019
Check out page 4, they are doing one better. Two slim 120mm fans mounted behind the GPU so air is pulled through one end and exhausted out the other.
Reactions: KSliger
penghutw
36
I am going to instantly preorder the SWOLE.
It sounds almost too good to be true.
Barely more volume than a node 75mm CPU cooler, 3 slot GPU, 145mm height and 330mm length.
Hit's every single one of my boxes, and more ventilation is always nice.
Targeted price is good too.
Reactions: HZCH and KSliger
KSliger
Sliger Designs
812
2,987
Is anyone really planning to lay this case flat, or would upright (takes up less desk space) be the primary way you'd orient it?
Asking because 3-slot version is really hard to make look remotely decent laid down, but I can do a pretty unique / modernish design when upright:
Poblopuablo
599
319
For me I'd stand it upright. Personally I'm not a huge fan of the slab base on the smaller model like initially portrayed. I prefer a foot like stand of the sentry/salvo models. But I appreciate the cost efficiency of the flat slab for sure. :)
penghutw
36
I would want to lay it out flat actually and add some feet or something, would be nice to have the option.
I get it if it adds too much to the design time/costs.
Reactions: KSliger
Allhopeforhumanity
401
385
I'd most likely utilize this chassis in its upright orientation to minimize the footprint. That said, I'm not even sure that a 3-slot thick chassis would fit into all that many entertainment centers laid flat anyway for that matter.
Reactions: KSliger
Leo
Is it stable upright? Tip-over proof?
Can you share some of your omni-directional designs?
I personally would fashion some magnetic feet myself, so if it's side mounting feet you're worried about breaking the aesthetic don't do that.
I'm one of those people anxious about my computer falling over.
Reactions: KSliger
penghutw
36
If it comes down to it I'm sure I could find some rubber feet with adhesive and make it lay flat if I wanted to.
Reactions: KSliger
loader963
598
524
I'd be doing stand up myself. By the way, since you are renaming the cases, do you think you should update the title post?
Reactions: KSliger
Retrias
23
that doesnt look that bad laying on the side , I am fine with either standing or laying down
Reactions: KSliger
Jibbajabbawockers
66
48
I was definitely thinking of laying this flat but I was also leaning more towards the smaller Console version, not necessarily the chunkier version. Was probably going to lay it flat using it hooked up to my TV. Granted, the cabinetry below my TV has moveable shelving so I could probably fit the chunky version flat too.
Then again, I'd probably get the vertical stand too in case I ever moved the case around too, but at least right now I'd probably be using either version laying flat.
Reactions: KSliger
tifaff
65
Im still worried for the termals in the small one...
Is there a way for you to expand the ventilation a little more in those places?
What do others think?
Reactions: KSliger
KSliger
Sliger Designs
812
2,987
Will probably keep the case almost identical to post on page 4, just changed the front panel to not use screws.
I increased the density of them vs all other holes on the case, won't look too odd but will help airflow.
I will include adhesive feet with every unit, save your $.
The 2-slot is very unstable without the flat base, doubt the 3-slot will be a whole lot better.
Doing a couple different ideas for the base, will post tomorrow.
I like the new version. It looks as if the case will get plenty of air from below with it raised up as you show.
Unfortunately this was not very stable based on CoM math, will have to make a future larger cases based on that design.
Rolling back to the original flat base plate for now due to the low cost and high stability. Tried a few different bend ideas and they all seem likely to scratch furniture or add $ to price for no reason.
Really trying to keep these focused on that lower price target.
chyll2
349
276
imo, go with flat base. I am sure you can easily add those good looking stand as an upgrade. And subjectively speaking, I see nothing wrong with the flat base.
Retrias
23
is that image in proportion ? if It is I am so on getting the conswole , I can do the lying down format inside my monitor stand as well
