...in search of a simple and convenient design...
This is a new line of cases made of steel. More strength and cheaper cost!
The simple case design allows you to conveniently assemble a PC in it and maintain it. The case can be hung on the monitor or on the wall using the VESA mount.
- Size: 2.1L (187mm x 190mm x 60mm)
- Material: Steel (1mm)
- MB: mini-ITX (170x170mm)
- GPU: none (integrated graphics on the CPU)
- Cooler: up to 43mm high
- Storage: 1 x SSD 2.5 "
The 2.5 "thickness of the drive reduces the allowable height for the cooler. - PSU: pico HDPLEX DC-ATX or Dynamo Mini
with external power supply unit 19.5V> 80-240W
SL2 3.4L rev.3 is the best mini PC case with internal power supply. It was designed for the top-end Core i7 and RYZEN 5 processors with integrated graphics.
First of all, this compact case is suitable for developers for whom only the power of the CPU is important. It is also ideal for assembling a PC as a media center.
- Size: 3.28L (265mm x 185mm x 67mm)
- Cooler: up to 48mm high
- Storage: 2 x SSD 2.5" 7mm
- PSU: FLEX 1U (41x82x150mm)
SilverStone FX350-G, Seasonic SSP -300SUG, 7600 ENP-Plat. 400 -600W, FSP GURU300 or other
SL2 3.7L rev.4 - steel case for mini PC with internal power supply. It was designed for Intel Core and AMD RYZEN processors with integrated graphics. The key feature is support for coolers up to 70mm high.
First of all, this compact case will suit developers who only care about CPU power. It is also ideal for building a PC as a media center.
- Size: 3.7L (228mm x 183mm x 88mm)
- Cooler: up to 70mm high
- Storage: 1 x SSD 2.5" 7mm
*maximum cooler height with this installation is no more than 60mm - PSU: FLEX 1U (41x82x150mm)
