I hope so! I bought those. They would go under the PSU.
Okay, thank you! Thats what I gathered from the drawing but I haven't seen any clear pictures of them to be sure.
Pretty sure that if you have a full sized card installed it is going to incredibly difficult to do so. The space below the psu where ssd's go has a small caddy. According to sergiiua it could only hold 15mm in total. You might be able to squeeze the 15mm on top of a 7mm ssd, however you need quite a bit of space for the psu cables as well. The modular cables with most psu stick out quite a bit (especially for the Silverstone sx600-g, less so for the corsair sf 450).Hey everyone! I have one more question. If I understood sergiiua's drawings right, the Revision 2.2 case can hold a 9mm ssd AND a 15mm 2.5" hdd, correct? Even with a full size GPU?
Thanks
Yes everything is correctHey everyone! I have one more question. If I understood sergiiua's drawings right, the Revision 2.2 case can hold a 9mm ssd AND a 15mm 2.5" hdd, correct? Even with a full size GPU?
Thanks
@sergiiua
Which length of Sata cable would be better for 2 SSD's under PSU in the ver2.2 case?
For example
2x 20cm
1x 20cm and 1x 30cm or
2x 30cm
Why would you need a 20cm & a 30cm...?
The SATA ports on your motherboard are not 10cm apart, nor are the SSDs on the other end of the SATA cables...
2x 20cm@sergiiua
For example
2x 20cm
2x 30cm
yes with each batch we improve the quality as possible.Has the quality of the cases improved? I just got my batch 2 case and the quality is really badPSU bracket bends really easily. Even my standard dual slot GTX 1060 won't fit so my sidepanel won't close. One of the motherboard screw holes won't line up. Lots of gaps and spaces between the panels. I really want this case to succeed because of its size.
Another party is ready. Thanks to everyone who is waiting for your patience!
need a little more timeany chance pictures of batch 6 will be up soon?
These case designs are superb. What size PSU does this thing support? I'm looking to put a pretty beefy build in here so I need a decent amount of power. I'm thinking i7 8700 and a 1080ti. Its looking like I'll need a 650w psu in here. Does anyone know if there is enough space? Does anyone have pictures of a build using this case?
