Hello Everyone. I'm posting my project here for anyone interested and answer any questions you may have.
322x264x161mm 12.7x10.4x6.3in 0.9Kg (With vertical feet.)
Please note the Line drawings do not show the connecting cube nuts. They're old illustrations.
For those seeing this project for the first time, I'm an Australian designer who made some lightweight PC cases for myself the way I like it. It's real Carbon Fiber, is modular and expandable in volume. A lot of people encouraged me to make one for them. So I'm cutting some. (More about me see bottom of post.)
This one starts 12.5L, and has bolt on self repeating blocks to increase its size. The vertical feet is technically the first expansion.
Some MODCASE Features:
About me: My name's Haydn Bao, been in manufacturing for about 20 years since I left school, as woodworker, then industrial designer, Mech. engineer and finally marketing manager of Altendorf GMBH (Asia Pacific Division). I’ve recently left my wonderful team and am now putting my expertise in a range of Carbon Fiber products in other industries.
- Expandable in all 3 Dimensions. (Self Repeating building CF block system.)
- Convertible to Open case. Or semi open frame.
- Unique high open rate mesh belt system.
- 3.5 PCI Slots. 7 slot by expansion. (Or more.)
- Rear 90mm Fan support, 120mmx2 Fan support on side.
- Large Mobo rear access door. It has quad symmetry, you can rotate the door and position vents over your nvme for example.
- Rear External Pump Res support. (To be tested.)
- About 900 Grams (Full setup.)
- Machined 3K Twill Weave Carbon Fiber + Hardened Steel construction.
- Easy assembly.
- More vent cuts added for PSU as per feedback.
- More vent cuts behind MOBO on the Door.
- Added Flat Carbon bars above MOBO instead of tubes. Allowing for 18mm of CPU cooler over hang above the Mobo.
- Stock CPU cooler height is support 137mm. (Unlimited Cooler Height with expansion.)
- Up to 240mmRAD support by default.
- F_Panel IO now fully modular. You can choose between USB C, A, and Power button or have all 3.
- Expansion updated into rear plate. 3.5 Slot ready. Unlimited PCIE Slots via expansion.
- Universal Hub Mount revealed. The long slot hole on the Feet, is for you to mount commonly available USB hubs/ card readers from behind.
