HI Guys,
I'm new to the SFF build community. Currently i'm looking into making a high-end build. For this I'm planning on using the new Skyreach S4 Mini.
Currently I have on my list:
CPU: Intel Core I7-8700, with a Noctua NH-L9i.
GPU: Zotac GTX 1080 Mini.
MOBO: ASUS ROG Strix Z370-I Gaming.
RAM: Kingston HyperX Savage Black 32GB DDR4-2666 CL15
PSU: HDPLEX 400W with a Dell DA330PM111
SSD: Samsung 960 Pro 512GB and Samsung 960 evo 250GB
According to some research from the NFC system channel and Linus Tech Tips, this should work power wise and would also not be very noisy.
Now it would be nice to replace the following parts to:
CPU: Intel Core I7-8700K, with a Noctua NH-L9i.
GPU: Zotac GTX 1080 TI Mini.
But for this I quess the Dell DA330PM111 wouldn't cut it at its regulair 330W. Now I have seen that there are some higher options, but they are like €400,- which is a bit insane.
Could any of you advice what would be needed (which would be silent and doesn't become extremly hot) that does the job, and does anyone know what the noise levels will be with a 8700K and 1080 TI?
Thank you in advance
Cheers,
Bryce
Cheers,
Bryce
