Hi my dudes and dudettes!
I'm about to build a new PC, and I wan't to use the Louqe Ghost cabinet (if I can get hold of it, that is). I also plan to get a top hat for CPU cooling going Ryzen). I have a couple of questions:
1. Due to the Loque having space for only a 40 mm ish GPU, I'm forced to go for a blower style card. Will the MSI ones be okay (larger exhausts than founder's) you reckon?
2. If the Louqe turns out to be a rare unicorn, can you lot recommend a small and _clean_ case with grills on the side that's able to fit a 2.5 slot GPU, and secondary a liquid cooler for the CPU?
Thanks!
Thanks!
