Nope, as you can see above, C: is the NVMe where W10 is installed, and D: is the SATA SSD where W7 is installed.
On boot I see the ASRock sequence where I have the opportunity press F2 to access the UEFI, F11 for boot device select, etc
and after a few seconds I see the W10 'choose your OS' screen appear, I use that.
Maybe the two installs and drives aren't truly separate as I expected them to,
I don't know if there was a better way to do this, honestly. What I grabbed from tenforums (frankly the only place I found information on the exact topic) was a bit too over my understanding and skills.
Hi - I am thinking about transitioning from Win7 to Win10. I have been running Win7x64 for a very long time on my main PC. I have done a lot of instal
www.tenforums.com
I have Windows 10 installed on one HD and running well. I've just added a second formatted HD where I wish to install Windows 7. My question - should
www.tenforums.com
I want to set up a dual boot system with windows 10 and 7. I have both already installed on separate drives in my desktop system and was wondering if
www.tenforums.com
Note: to make things maybe more complicated, the Windows_7_Image_Updater app I've used to mod the W7 image, actually integrates the W10 installer.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper
forum.videohelp.com
