We ship out directly from Hong Kong by FedEx. And for EU region it is VAT/duty included (DDP - delivery duty paid). Takes about 7 days. So it shouldn't be that much difference than if it were to be shipped out within EU.Are there any distributors in europe or is that something you are working on?
Thats nice to hear.We ship out directly from Hong Kong by FedEx. And for EU region it is VAT/duty included (DDP - delivery duty paid). Takes about 7 days. So it shouldn't be that much difference than if it were to be shipped out within EU.
Actually storing the goods in EU warehouse first incur additional costs (1 more leg of shipment and warehousing). We tried before, and there is not so much benefit.
The sub tab in product page mentions explicitly EU/UK prices include VAT/duty. Other places not being mentioned, then for those local taxes not included.Thats nice to hear.
Read the shipping policy and it stated: Nouvolo offered prices don't include shipping costs, duties, import taxes, and/or related fees, unless stated explicitly otherwise in the specific product offer.
Totally up to you and depends on the loop config. But please note that there are differences between the in & out ports in terms of head pressure. You can use the in port as fill or drain port. Whereas out port should only be used as drain port.Does the orientation matter?
Should the ports be on the right next to the RAM or left next to the I/O ports?
Just our recommendation for a standard custom loop build, but it's totally up to you on how you design your loop. If you run a split loop by all means use those extra ports to divert flow to other parts of the loop. You can try prototype your loop build without the computer hardware first, anything goes will goUncle nouvolo, then the side ports are for fill (inlet) and bleed (outlet)?.
We have some feedback, for some 1700 motherboards the CPU sockets are slightly lower (talking about~1mm). Due to the tight tolerances we suggest you add washers (2mm thick) to the thumbnail screws (those with spring). This will solve the mounting pressure issue.Has there been any testing/verification for 12th gen Intel mounting at all? I’m having some very inconsistent temperatures using the Aquanaut Extreme as are others of the SFF gurus Disc. I also don’t believe the mounting pressure is adequate at all. As I have mentioned previously with my 11900K in the thread, the whole block wiggles left to right and doesn’t feel adequate. Screws torqued to 0.6Nm using EK’s screwdriver. The EK Velocity2 performs significantly better.
Would love to know if you guys had similar issues in testing .
Appreciate the response. I do believe that I still had issues with the mounting on my 11900K as well so I don’t believe it’s just a 12th gen socket problem and more of a inadequate mounting solution. Is there any plans to address the flaw moving forward aside from the mentioned washer “mod”?We have some feedback, for some 1700 motherboards the CPU sockets are slightly lower (talking about~1mm). Due to the tight tolerances we suggest you add washers (2mm thick) to the thumbnail screws (those with spring). This will solve the mounting pressure issue.
Washers below are quite common and should be available in your local stores, or on amazon.
Many spring loaded screws use washers anyway. We will see, maybe on next major version update.Appreciate the response. I do believe that I still had issues with the mounting on my 11900K as well so I don’t believe it’s just a 12th gen socket problem and more of a inadequate mounting solution. Is there any plans to address the flaw moving forward aside from the mentioned washer “mod”?
It doesn't happen to all users, only for some motherboards...Many spring loaded screws use washers anyway. We will see, maybe on next major version update.
Perhaps you should let customers know that what they’re buying isn’t truly compatible as it’s being marketed, to prevent them from wondering why they’re getting such horrible temperatures.
Edit: The silver lining being that my temps under CB dropped from 95+ with throttling down to 82 max with no throttling. So for any 11th/12th gen intel lads out there, 2mm of washers is an adequate Band-Aid.
Okay well then compile a list that your product isn’t compatible with and make users aware of the fact that it’s not a one size fits all solution and a washer remedy is required.It doesn't happen to all users, only for some motherboards...
I’ve heard from other users that have attempted to reach out and confront this issue and it’s been largely ignored from Nouvolo’s end.
I have been following this from the sidelines for a long time.This is a strong claim... Anyway we can only report on what actually happened on our side. We believe we have a decent if not perfect reputation in terms of solving customer's issues, at least for a small creator.
We receive a relatively small number of feedback with such issues comparing to the number of Aquanauts we have sold (1 in 50 approximately). We have replied and suggested the washer solution to all users who has emailed us. And we always try to make improvements on version updates.
In the meantime, our suggestions of using washers should be a good solution to the issue. Appreciate if you could try it out.![]()
I would say that 1/50 customers reporting this issue is quite a significant problem.
"We believe we have a decent if not perfect reputation in terms of solving customer's issues" I can't say this is the atmosphere I've seen around Nouvolo products, more of the opposite really.
Lastly, you suggest they try out the washer mod, except they already did and reported their results with it it.
