Production Aquanaut Basic/Extreme - Ultra Low Profile CPU Block & Pump Mount Combo
spdfrek
36
64
MCP35X is DDC standard and should be compatible. But this is quite an old design (still comes with molex connector), released some years ago. Not sure if there are better ones out there now.
Mcp35x works fine. Mine was rewired to just a pwm plug, as my mobo has a 2a header for a pump. If you want a sata plug, grab the ek ddc 4.2. As far as performance goes, you shouldn’t see much difference between those two pumps.
Nouvolo
Creator
Sep 8, 2018
760
1,713
Hong Kong
www.nouvolo.com
Be very careful with getting pump power directly from motherboard. Some say that the pump draws much more power on start up and may exceed the quoted spec for a short period of time. That's probably why nearly all standalone pumps are sold with separate power connector via SATA/molex.
Goatee
739
1,513
I have used a 2A header on a mobo but my preferred option is a quadro from aquacomputer. It’s fan headers are software controlled, 2A each and it’s a nice little package you can hide away somewhere.
The other fan headers are really useful for controlling radiator fan speeds based on your loop fluid temperatures using it’s temperature probe mounts.
2,195
2,212
Norway
I also use a Quadro for pump and fan power and control, and I'm very happy with it. Though I have heard reports of startup current from DDC pumps damaging those as well - one person told me theirs had three burnt-out, non-functional fan headers from this. Mine is so far entirely fine though, about a year in. It might help that my pump never goes from off to full power, or it might be that my exact model has a lower startup current - or I migh just be lucky (so far). Still, I'm willing to take the risk as it's a relatively cheap and tiny piece of hardware.
spdfrek
36
64
I’ve been running off of a motherboard header for awhile now, no issues. 3 different models of motherboards along the way. They all had a high amperage pump header on them though. I wouldn’t recommend trying it on a standard header by any means.
For the quadro users, do you have start boost on? There has been some discussion on how much more amperage the pump is fed with that on, vs off at startup. Might be worth a look.
robojim
254
222
New York
Anyone have a recommendation for a small reservoir? I have an EK Pump Res but thinking of moving to this and selling my pump/res + CPU block.
Goatee
739
1,513
Something like this works great! Just remove the impeller and reassemble. Has 3 ports on it.
I still wish I had purchased a load of these, removed the wheel and sold them as "Pico Res" for double the price. Here is How I used it.
NRG
289
359
33
Melbourne
It’s a bit jank, but you grasp the intention. I plan to cram it inside the case as this was just a proof of concept.
The plan was to have a T with a right angle facing up so that I can top up the res and it should in theory catch any bubbles.
2,195
2,212
Norway
That's my recommendation as well. I wish I had gotten one of these no-name ones off Ebay or Amazon, as I ended up going for EK's version (the only thing available locally), and it has a really thick back wall meaning it has about half the internal volume it could have had. It still works decently, but the simpler ones are definitely better. I've stuffed some bubble-catching foam I had left over from an old EK reservoir in there, and it really helps avoid recirculation of bubbles, so that's highly recommended.
Nouvolo
Creator
Sep 8, 2018
760
1,713
Hong Kong
www.nouvolo.com
I totally recommend Alphacool's rad, don't see the reason not to get this one. It has extra ports for filling the loop, and if the rad is placed at the top of the loop it can also serve as the bleeding port as well (and can omit reservoir in build, for ultimate space saving). I cannot emphasize how much hassle you can save with this kind of radiator. I am using this, and reservoir is not even considered in my shopping list of water cooling parts 😁 (unless you are EK fanboi 😭 )
DrHudacris
918
1,720
USA
View attachment 1695View attachment 1697
Also I highly recommend Leviathan SF240 for the same reason (and it's branded hardware labs L series which is a higher plus).
robojim
254
222
New York
I already have a Corsair 280mm but in fact that offset port is interesting. Anyway I will first try to get it working with the Iceman Res/Pump on the inside. If that fails, I'll pivot to a reservoirless build indeed.
duynguyenle
331
331
I've been partial to HWLabs rads for my previous builds, but I agree with Nouvolo, if you're doing a build in a challenging case, the Nexxos V2 builds with the end tanks having ports on both sides plus a fifth port that you could use for drain or bleeding air when filling the loop is really a BIG BIG help.
I used one of those rads to put together an AIO-ish loop without a reservoir using Alphacool's pump/block combo, and having the extra ports in the rad was an absolute godsend. Plus they're priced relatively competitively with other brands.
