368 USD each for the WX7100 on Aliexpress. Not bad at all.
https://www.aliexpress.com/store/pr...eon-WX7100-8GB-Tested/613679_32969988418.html
Think it would work with the Z390M-STX MXM?
No idea, but I kind of hope you have 400 bucks burning a hole in your pocket![]()
They have been released... but can't find any in stock at least here in UK.Has anyone looked at temperature drops for intel cpu when you disable the igpu? Can you disable permanently? Or better Q anyone know when coffee lake "T" cpus will be released?
Considering that they launched literally three days ago, that's no surprise. Wait a bit, they'll come around.They have been released... but can't find any in stock at least here in UK.
A card with HBM2 would be perfect for MXM since you're only cooling a single chip package rather than discrete RAM chips.
As for temperature drops when disabling the iGPU, they should be negligible. If you're using a dGPU, the iGPU is largely power-gated anyhow, with the exception of workloads making use of fixed-function hardware such as QuickSync video encoding.
Ah, I thought you meant 9th gen, not 8th. In that case, I'd guess they're out of stock as they're about to be replaced by newer SKUs.
I was referring to the 35w CPU's T series.
As I said, they launched 3 days ago. Probably haven't started showing up yet, but it's still logical for retailers to sell out and not restock (particularly for low-volume products) when replacements are on their way.I cannot see the 9th gen either. I can see the F non igpu but no 35w T variants?
It's been there for a while I think? I must be honest I treated it with a pinch of salt, I understand why, but most things there seem to be out of stock/place holders. That said if/when they appear I think I would be moved to purchase because I really like the STX form factor (still a PC but not massively bigger than a SBC).Oh holy shit balls, they are stocking the friggen MXM cards themselves! That's sick as!
Just need to find someone who can make a custom full cover monoblock.
The board has been there for awhile yes, the option to select an MXM GPU alongside is new however.It's been there for a while I think?
