Hello, I understand these are the GPU restrictions from the ncase product page:
Maximum card length:
I have a Zotac 2080 AMP with these dimensions:
308mm x 113mm x 57mm (12.13in x 4.45in x 2.24in)
1.) This is probably a stupid question- but a micro ITX motherboard only has one PCIE slot- how do I even decide if the GPU goes in slot 1, 2 , or 3?
2.) A bit confused about the PCB "extending to full height" warning. By the linked pictures it sounds like it's saying if you see the top connectors extend past the body- then it won't fit? So this is my video card- https://www.bhphotovideo.com/c/product/1431192-REG/zotac_zt_t20800d_10p_geforce_rtx_2080_amp.html
is it incompatible?
Also the CPU restrictions say this:
Coolers are limited to 130mm in height with the side bracket installed, and no fan installed.
I have a wraith AMD cooler (came with 2700x). 3.) Why would they provide a height restriction without a CPU fan installed? - Obviously you can't just have a heatsink on or the CPU will overheat.
Thanks so much for the help!
- 317mm in slots 1 & 2
- 279mm in slot 3
- For cards up to 317mm, or for cards in the third slot: 111mm
- For cards up to 292mm in length in the first or second slot: 140mm
- For all cards: 120mm at the PCIe power connectors
is it incompatible?
- When mounted, coolers cannot extend past the top edge of the motherboard by more than ~10mm. For many larger coolers, this limits motherboard choice to those with centrally-located sockets.
- Large coolers that extend past the front of the board preclude use of the 3.5" HDD cage.
