Cooling 80 x 80 x 10 mm case fan... doesn't seem to exist?
ImmaculateDoge
Hello all,
First post! Is it possible to find a good 80x80x10mm case fan? Some googling and searching on the forum only turned up one from Akasa, mentioned here. However, the Akasa model seems to be noisy and of low quality.
I'd really like a couple of nice quiet 8010s for a planned build in the ZS-A4m. Any suggestions are appreciated!
Thehack
Creator
Mar 6, 2016
2,800
3,650
J-hackcompany.com
It's pretty much impossible to have a good noise profile. At 10mm that's not a lot of room for a good bearing and hub design. It also means the fan blades are less than 10mm deep, so not a lot of airflow to be had there.
You get what you get. Just slow down the speed as all it does really is prevent stagnant air. Not a whole lot of airflow. 80x80x15 is a bit better.
Reactions: NinoPecorino
KMPKT
3,382
5,936
Ah crap sorry. I simply read the last post and replied.
jØrd
S̳C̳S̳I̳ ̳f̳o̳r̳ ̳l̳i̳f̳e̳
sudocide.dev
LOSIAS
Jul 19, 2015
818
1,359
Have you thought of maybe 4 of the Noctua A4x10 fans together. A rather expensive solution but ticks the quiet and quality boe
Out of interest have you actually tried this. I'd be super interested to see some results / feedback about the noise profile vs a single 80
Sandez
Unfortunately not, but I'm in the same boat as you. Would be interested in the results, but more from a FYI point of view
7,143
I'd expect the 4x40 solution to be significantly inferior. That and 40mm fans are the worst for noise profiles. Trust me.
Regarding the original question - well, after 30 minutes of digging, I can't find any others except the Akasa and Evercool options. Dang. IIRC Noctua is working on one, we keep nagging for it to be fast tracked, but to no avail :(
Jacko-4
Did you ever find a fan? There is this one, the silverstone SST-NT08-115XP. It is attached to a heatsink though.
ImmaculateDoge
That would work in a pinch. Never heard of this product before. No I didn't find a fan but the project is on back burner.
hat1324
146
100
I use these now for my Scythe Jitte cooler. They're about as noisy as the Akase but they seem to last longer for half the price, and the Jitte really kills fans. I expect they'll be available for as long as Velkase is making their chassis
Rich Tea
40
23
Anyone seen these fans before?
Scythe Kaze Hachi 80x90x10mm SC8010KH12H-P
  • Brand Name: SCYTHE
  • Dimension: 80x80x10mm
  • Model Number: SC8010KH12H-P
  • Type: Protective Net
  • Weight: 37.7G
  • Type: computer case fan
  • Bearing: Sleeve Bearing
  • Rated Voltage: DC 12V
  • Fan Interface: 4PIN PWM
  • Rated Current: 0.15A
  • Air Volum: 25.8CFM
Googling the model number only gives assorted chinese results. Could be a new product? or a fake product? Might be worth contacting Scythe and seeing what they say. Found a picture of the back of the box here. Can't quite make out how many dB this makes. 30.7dB?
I was looking to get the Akasa ones to do a mod on my gpu, and comparing the specs it seems that the Akasa are superior in all aspects expect the asthetics lol.
Dimension80 X 80 X 10.8mm
BearingEnter Bearing
Speed600-3000 RPM
Max airflow26.53 CFM
Max static air pressure1.81 mm-H²O
Sound level27.09 dB(A)
Rated voltage12V
ConnectorPWM-4pin
Product codeAK-FN076
hat1324
146
100
  • Weight: 37.7G
Speed600-3000 RPM
Rated voltage12V
ConnectorPWM-4pin
This is the fan that comes with the Scythe Jitte... In my experience, it began to wobble within several months. That said, the Akasas lasted even shorter, so given that the VELKASE fans are OOS on eBay, they're probably your best bet.
Anyway point being I believe they are legit
Reactions: Rich Tea
Rich Tea
40
23
Cool nice to know they are legit. From your experience if they aren't much better than the Akasa then, I probably try the Akasa out based on cost alone.
I need 3 so it would be £28.17 with a chance that I might need to play import duty on top. Whereas for 3 Akasa's it is only £16.44 delivered in the UK.
And as a temporary mod I dont think its worth paying almost double.
Thanks for you input
