I have found an extremely space efficient mATX layout supporting many mainstream components. My goals were to have:
Everything just barely fits, and I did check. Any bracket or panel is mounted to the frame using M3 screws. Fans that are compatible are 120mm standard thickness. This was made with SketchUp. Panels do not have any thickness to them yet, but will likely be 2mm aluminum.
- To have absolutely, the smallest, most reasonable fully mATX compatible case possible.
- Support for a 240mm AIO.
- Mainstream PSU support, it being SFX and SFX-L.
- A simple build, with easy access.
- To have it be portable.
This is a really rough draft, and this may need some edits, please don't be mean, and if you feel like it, help. You can help me by recommending a change to something like the side and top panel, which at current, sort of works like the Ghost S1.
