Hello again. I've finished my visual prototype of my case, and I personally think the front isn't great, but the side panels look pretty good.
Not much else changed, the Rad bracket does still have widened mounting holes for more room. The two side panels, and the top panel are all connected, and slide into a rail, and screw in on top. Any bracket in this pc connects using a M3 screw.
Dimensions with outside panels (L*W*H) 345mm*159mm*290mm.
120mm*25mm case fans can be mounted under the gpu.
Now I need suggestions, and a name for the case.
