Stalled Z-CASE P50 v1.1: Innovative console-style SFF PC case
Status
Not open for further replies.
Freddytulips
Does anyone know whether or not the psu cable is suppose to just fit more or less perfectly through the cut out on the back of the case? Mine is too large despite being the correct rounded square to actually fit properly through the cut out and I've found no real way to mount it against the cutout with the screws supplied w/ the case. It's a problem I had from the beginning but overlooked it at the time. I also have very little idea how the power cables are supposed to route perfectly (not neatly but hidden) beneath the psu shroud. Have recently disassembled my build to fix these issues and figured I'd ask here
JohnCA
55
23
Just to show off what I've done to the Z-Case. This is probably the way it will stay for a while, with exception to some airflow control with thin clear plastic sheets that wont be seen.
Have a look:
Wow, is this a 7 inch LCD screen? Looks awesome, can you show us how you made it work? :eek:
chrimen
52
Have a look:
That's exactly what I was thinking when i was thinking of making an acrylic panel. The diagonal vents. What are your temps like with these vents?
Looks sweet!!
chrimen
52
Have a look:
I was wondering how you did this, what tools you used and technique. I've been wanting something exactly like this for a while now.
Freddytulips
disregard this, figured it all out ! :)
Reactions: Daniel.f2277
dacst
is anyone else having an issue with the psu shutting off the pc? everytime i try to run a game the pc shuts off. i know its the psu because i connected my 1200w psu to the system and everything ran fine. i have an 8700k (no overclock) and a 2080 ti (overclocked). shuts off when 2080 ti is at stock clocks as well.
dacst
What PSU? The enp-7660b from them?
@dacst
yeah, the custom one that they are currently selling and that came with the case with the first batch of case orders. if i play on 1080p its fine but once i go to 1440p/4k it shuts off. bummer because i was planning on using this as a "console" in my living room.
Reactions: Syncro
britsches
i think yours might be faulty. there is no way you pull that much power to trigger the overcurrentprotection - normally that is.
JDragon
86
64
Mine works fine with a 2080 Ti at 4k 98hz fwiw.
dacst
thanks guys. i see enhance offers a 1yr warranty. hopefully i can get an RMA on it.
6,591
We've had ongoing issues with the user SFFTEC and unfulfilled orders. We are investigating the issue. In the mean time, buyer beware. I'll leave this thread open in the mean time to enable community tech support.
britsches
Can confirm, i had issues with my order as well, but at least i got one case delivered. Yet the wrong color.
Tute
70
39
Well i've got an Enhance PSU coming from him hopefully at some point, i've not chased it as naturally the planet is a bit messed up with regards to manufacturing and delivery at the moment so i'm happy to be patient.
I am hoping to get it at some point in 2020 though?
SFFTEC
SFFTEC
Nov 17, 2019
62
172
www.sfftec.com
UPDATE
The Z-CASE P50 v1.1 batch is ready, and will be shipped in around 2 weeks.
It will have lots of improvements as you can see on the pictures, please check the 1st post for more info.
We still have very few units left that can be purchased here.
Let me know if any questions ?
Status
