BTW I found this layout where the GPU backplate is facing outwards extremely well suited for water-cooled builds. Gotta use all options to radiate heat passively! The other side of the GPU will be covered with a waterblock anyway.
Find many great new & used options and get the best deals for Copper Base Platform Common GPU Water Cooling Block Liquid Cooler at the best online prices at eBay!
www.ebay.com.au
and i cant seem to find the file for the am4 mount, i vaguely remember measuring it up and sending it straight to the laser, i must not have saved it :S
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
