Curiosity
- Apr 30, 2016
- 724
- 838
Curiosity submitted a new resource:
X300-M(AX) case F3D file - Full design file for my x300M based case, supports a 140mm rad and a full length 2 slot GPU w/in 6L
F3D file for the X300MAX case, 5.7ish Liters depending on the side panel used.
Cutout for an XT60 connector at the rear for power out, uses a 3W3 Dsub connector for power in, ideally pins on the case side.
Specifically designed for use with the Corsair XR5 radiator, and even then will require a relief cut in the motherboard side overlapping the Rad for clearance, or direct mounting it to the spine.
Motherboard standoffs should be 6mm tall and mount to the GPU side's rear, passing thru the...
