Hello guys! This is my first post on the forum. I'm an SFF lover, and have been following the forum for over an year. I decided making an account now and posting this thread because I think I might have had a cool idea (if it is possible to build, of course).
So, basically, is making the smallest viable mini-ITX gaming PC. For that to be possible, the critical points are: using picoPSU, using a low-profile GPU, and manufacturing a custom bracket (IO shield) for the motherboard and GPU (4,5cm bracket for the MB and 7cm bracket for the GPU).
I know 1,99L would be the best case scenario, which may not be achievable. So i remind you: the purpose of this post is hearing your opinions about it, as this is just an idea. If you guys think it may work (even if it has to be a little bigger), I might start a building log.
So, the hardware would be the following:
- Any Mini-ITX motherboard (17 x 17cm)
- Any CPU (preferable <65w, because picoPSU is not that powerful)
- Low profile CPU cooler (<45mm)
- Low profile RAM
- picoPSU 160w + AC-DC adapter
- Gigabyte GTX 1050 Ti OC Low Profile 4G (Size: 16,7 x 6,9 x 3,7cm. Wattage: about 70w)
- One 2,5" SSD (10 x 7 x 0,7cm)
CASE SIZE: 17 x 24 x 4,9cm = 1,99L
*Total wattage: around 135w
In theory, reaching the 1,99L volume is possible. But in practice, I know it probably won't be, as I forgot to count some small important spaces, like the motherboard standoff, PCIe riser needed space, and some other safety distances.
Here are some scratches I made (dimensions are not 100% accurate), to make the design more clear to you guys:
TOP VIEW (without the GPU)
TOP VIEW (With SSD on the bottom + GPU on the top)
SIDE VIEW (from the back)
So, what do you guys think? How difficult is it to manufacture a custom bracket (IO shield) for the motherboard and GPU? What are your thoughts about the design?
Cheers!
- Low profile RAM
Cheers!
