What's the distance between the two fans (green boxes)?
It's 172 mm with the step file from the homepage (with 25 + 30). I adjusted the rad to 29,6 for the GTS in my screens and might need to add 2x 2mm for the P14 if I end up using them (27mm instead of 25mm)
Just so you're both aware,
The real height is 176mm, assuming you have a 30mm radiator, and 25mm fans (total of 55mm
exactly - please remember to account for tolerances!)
This was done purposely, as the simplified CAD file for loop planning
under-reports the space you have, so even if you run right against the limits in the file and your real-life parts have loose tolerances, they will still fit in the actual case. Most people do not account for tolerances when they are playing with dimensions, and most tolerances are unlisted for off-the-shelf computer parts.
So we measured a bunch of them, created a library of tolerances, and then planned case dimensions accordingly.
Radiators are *notorious* for having +/- 0.5mm variance (due to how they're made) and PC case fans typically are made to +/- 0.25mm. So for radiators, we allotted an extra 1mm of space, and for fans, we allotted an extra 0.5mm of space. Now, consider top surface + bottom surface + interface, and you get 0.5 + 0.25+ 0.5 +0.25 = 1.5mm Then, keep in mind that most tolerancing is 2 standard deviations, or 95% of all lengths on a standard distribution, as some things will slip past QC that are sliiiightly outside of that range. (1.5mm / 0.95 = 1.58mm).
So what I usually do is add a 1/3 safety factor on top of the summed dimensions to encompass all part variance. So you get 1.5 * 4/3 = 2mm. Now, stack those two together for the bottom and top set of fans / radiators! (2mm + 2mm = 4mm)
That's why the Loop Planner Shows 172mm instead of 176mm
Some of you might be wondering "Why not give us true dimensions?" -- In my experience, this leads to all sorts of issues with parts requiring sanding and such to get a fit. This is not a good experience, and I did not want to ruin the build experience for newer builders unfamiliar with how tricky dimension matching can be with SFF, especially when most manufacturers do not list tolerance on their provided dimensions. I tried this approach with the Beta Units as well, and that's why we had zero fitment issues with the Beta Unit.
