Awesome work... do you have an estimate of how heavy the SPK will be?
SPK is still under NDA, and won't be out until next year. At current, you can expect it to weig around an NH-D15, if that helps.![]()
I've been testing a few air cooling configurations with gtx 1060s. Wintercharm asked me to test a bunch of different ratios of "solid to open" walls (I taped cardboard strips of varying heights where the side panels would go). He's doing all the analysis stuff on it, so I'm not going to dive into it too too much, but the results were interesting, and should have lasting implications on sandwich case design.That's lighter than I was expecting! Are any of the beta testers going to do full air-cooling builds? Would love to hear how they go
I have a full air cooled build. This is the coolest and quietest my RTX 2080 Ti FE has ever been in any case.That's lighter than I was expecting! Are any of the beta testers going to do full air-cooling builds? Would love to hear how they go
Yeah, we had to do some troubleshooting because airflow in this case is so strong it actually hurt thermals in one of the configurations by fighting the GPU cooler, but once we got that sorted out, it's been smooth sailing ^_^
Are those the feet the retail unit will ship with? Something about them cheapens the look of the case, imo
Looking at the pictures of @Qzrx I just realized I might have a problem with my GPU width. From the picture it looks like there's not much more space left, using the magicool (27mm) + noctua (25mm) + the reference vector (127,6).
I was thinking, if the 3090 FE will fit then im fine, but I forgot then you wont calculate in the radiator. Additionally the HW Labs 280 is almost 30 mm and the most popular 140 fans P14 or NF-A14 would be 27mm.
Long story short, could you include the possible length of gpu width (height) + fan + radiator when finishing up the specs?
The EK-Classic block raises my trio to 152,5mm ?
This case looks great! My only concern is the lack of 30mm rad support if you want to use 25mm fans. There aren't that many great sub-30mm radiators out there last time I checked. I personally would not have minded if the case was a tad bigger in order to accommodate something like a GTS 240 + A12x25s.
Although there is the recently release NexXxoS ST25, but I have yet to see any benchmarks. Hopefully they came be competitive with the GTS. They could be perfect for this case.
Alphacool Introduces NexXxoS ST25 Slim Radiators
Alphacool introduces the NexXxoS ST25 Slim Radiator Series featuring a 25.5mm thickness making it suitable for compact cases with tight radiator mounting spaces.www.vortez.net
Really looking forward to the Kickstarter. I put some money aside just for this case.
Oh wow! I didn't know you were making that change. From the bottom of my heart, thank you so much! This really was my only concern regarding this case. Now it truly feels like my dream case. I can't wait!These are the retail feet. However, trust me they're anything but cheap. All the beta testers who've held them have said they *love* the feet. Also, they're padded with Cork on the bottom so they make a nice "thwok"sound when you put them on a surface.
They feel *really* good. And they're necessary for airflow.
I will be sure to list GPU height specs / restrictions in the final specs. and be specific about water cooling vs air cooling clearances. v 1.1 (the KS version) will have some minor dimension changes.
Because of Dimension Changes that added 3090 support, the case is also being updated to support 30mm radiators + 25mm fans. While the Beta was restricted to 27mm radiators + 25mm fans, the final version will not have that issue
It was frustrating for myself, and the beta testers, to find slim radiators, so I completely sympathize with that, and it's one of the main reasons we decided to make some changes.
While looking over some of the pictures you posted, I noticed that there is a mesh/perforated side panel. I got me thinking, would it make any sort of sense to have both rad as intake, and have the air be pushed out through the side panel? That way both radiators are takin in cool air.
I am not sure if you've had the chance to test something like that.
That was very informative, thank you!See THIS post by WinterCharm, mainly the fourth CFD image. All intake is not recommended.
