Making your own heat pipes, HAH! I'd have nightmares making sure the capillary system on the inside is there correctly to transfer the liquid properly even during bends..![]()
Some copper pipe, a low boiling point liquid, something to facilitate it's rapid heat exchange...
This is a great idea! Maybe it would be possible to make a heatsink that is the entire case.
I can't find the case I'm thinking of, but LTT did a video long ago on this case. Lian-li has a mini-ITX case like that one (might be thin-mini).
The one I'm thinking of is a aluminum cube with a stand at the bottom, HardwareCanucks did a review of it.
I can try to dig up links if you're interested.
How are heat pipes and fins normally joined in manufacturing? Are they just kind of slotted into each other? Like, are the pipes fed through holes in the fins?
I think he may have been asking how the pipe and fin array are put together, like if the the fins are stacked one by one onto the heat pipes, if the pipes are fed through holes on a completed fin array etc.They're soldered.
IIRC most heatpipes now use copper (or other metallic) foam as the internal wick, rather than internal capillary grooves. You can buy bulk copper foam pretty easily, so cutting it to size and inserting it into a copper tube should be possible to DIY. The tricky part would be if it needs to be bonded to the outer copper tube (e.g. solder, braising, adhesive), or can just be in contact.That's not enough, though. Heatpipes have an extruded capillary structure on the outside, without that they won't really work. If you want to do a DIY heatsink, get heatpipes and bend them yourself. That's absolutely possible. But making your own, not so much.
Alternatively, a large heatspreader oder coldplate or how they're called might be a good base to solder fins onto.
