Copper is roughly twice as good at conducting heat compared to aluminum, for what it's worth.
This is accurate (in values ranging from 1.5x to 2x), check out conductivity values at The Engineering Toolbox
here, and the Engineers Edge
here.
Yeah that sounds about right. I've actually heard that aluminum is actually better at transferring heat to air than copper and that the holy grail of coolers (short of using silver) is having aluminum coated copper fins. Can anyone confirm this?
This sounds right to my pea-brain. Aluminum should allow the heat to GTFO faster as, since its density is much lower (check out table
here), it lacks the ability to store the heat as efficiently as copper. So this seems like a perfect idea, better conductivity with copper for heat transfer and aluminum to let it go, let it go...
Silver, interestingly, has a slightly better heat conductivity value than copper (although not by the same margin as Al. vs Cu.)
however its density is still quite a bit higher than copper - meaning it would store the heat better and would require more force to remove. So - the holy grail may well be silver fins coated in aluminum (or aluminium, hehe).
Although, from what I know - Al. coated Cu. seems like it would be the best (and most realistic) as you say - at least following thermal rules...
