Other What's on Taobao
Fueled By Yams
38
35
Hey, so I've been eyeing these WDEAN DORA cases, like their rip-off of the Ghost or MJOLNIR. Not at all serious about buying one unless someone else has experience with owning one. They look great in the pictures, but taobao cases always look great in pictures. I'm wary of them. Does anyone have one?
Renderings of the "R1S"(Ghost) Actual pics of the "D2S" (MJOLNIR)
(sorry, the forums didn't like the pictures copied address)
Superbuy does give a warning that they don't accept paypal, so they seem sketchy
Basically, I'm trying to find a sandwich-style case that can fit either a hybrid card or a 2.75 slot strix card (which is why I'm looking at the D2S). I'm waiting for the Sidearm T1, but exploring other options as well. If anyone has suggestions, I'd be down to hear them. Thanks!
Reactions: aggressivehog
Monfy
Check out the ZS A4 on taobao. I got it for my 2.75 slot gpu (49 mm rog strix 2070). It also comes with two back plates for different cpu/gpu heights.
Reactions: Fueled By Yams
Fueled By Yams
38
35
Thanks for the suggestion. I actually was aware of that case, I’m just slow and forgot that the second version supports three slots. Tbh it isn’t my favorite aesthetically, but I’ll keep it in mind ?
Reactions: Monfy
Nanop
hope i am not late with this, found a new project on taobao which looks pretty good,
If he add some vent of course
ywori
38
30
I have been trying to buy warhead papyrus for the longest time. In the end got a refund. Seller is unresponsive and contact person on taobao is outsourced to some form of customer service. If anyone knows any case which has a small gpu with the same layout :
please let me know!
prayogahs
236
343
please let me know!
Its quite an unusual layout but I found a few cases a bit similar.
L01
L01S Super
Interstellar i2
ywori
38
30
L01
L01S Super
Interstellar i2
Thanks for your quick reply @prayogahs
First 2 more of an M1 layout?
Last 1 I am not even sure the pictures represent the product?
I have sent a message on taobao to interstellar for accurate pictures. I will let you know if I get a reply.
BTW really nice case list you did. I do browse through that quite often.
prayogahs
236
343
Thanks, and yeah the first two is more of a M1 layout, theres not much like the Papyrus as its a unique layout. Sorry that I am unsure of the interstellar as its quite new. Hopefully the seller can reply you.
OnionFromOrion
please let me know!
The Papyrus is pretty unique. Closest I can think of are the Captain S.V6 and Sunmilo S01
ChrisMCP
49
Hm, is it 240 compatible? It's 3 slot but looks like no AIO support.
Also another Ghost clone by the same company. Which makes it the 7th Ghost clone I've seen.
Also I've just discovered Captain S.V2. Seem like a great case in Sidearm style but with 240 support and drilled alu panels option. https://www.chiphell.com/thread-2147655-1-1.html
Reactions: Nanop
hereforthefeast
132
133
Man the 2s looks so good. I have been wanting to move down to this size for a while.
However, having a 3700x and seeing the temps in the thread here: chiphell is a bit scary. Do you think there might be better luck with a loli1 instead? Maybe having the top fans could help out a bit. But if it wasnt for those temps, I would definitely go in on the 2s
Holy crap this is a beautiful case - I just wish it had space for 2 slim 80mm fans up top like the LZ-A4 mini https://item.taobao.com/item.htm?id=582590926138
tinyitx
2,279
2,338
Seems the NZXT H1 is drawing some attention and I just come across a square small tower case in Taobao.
It is slightly larger than the H1 and comes in at 200x200x386.
Unfortunately, it is offered as a fully prebuilt system.
Video link: https://www.bilibili.com/video/av88037712/
prayogahs
236
343
It seems to look similar to the Monster-01/M01. Is it the same one?
sunrainsky
35
Have this been posted?
fu致这行话€JaJY15aFbKx€转移至?淘宀┡ē?【matx机箱 艾罗拉M40迷你全铝机箱matx 小机箱侧透电脑 itx机箱】;https://m.tb.cn/h.VdKD3p5?sm=6e756e
It has space for bottom two Fans.
The cooler height is 120 but some say 130. 120 would fit a Noctua C14S.
One buyer even taped a slim fan on the top of the case.
It's similar but not quite ncase M1. But it's much much much cheaper.
Reactions: prayogahs
tinyitx
2,279
2,338
They do look alike (the rear panels look very similar) but they are not the same.
I have not checked the interior but one (at least) external difference is the top. The M01 has a 'cover' vs the 'Small White' has a vented top.
ChrisMCP
49
where is the GPU IO on these cases? is it a passthrough of some kind?
Any other good alluminium vertical cases by the way? NZXT is steel and looks cheap, but I like the concept
edit: nevermind, it's at the bottom, kinda stupid with the wire needs to be bent
prayogahs
236
343
I didnt see it before, its similar to NCase M1 but has a lot more similarities with Metalfish S5 and Mechanic Master C26. Thanks for the finding!
tinyitx
2,279
2,338
This only looks bad if one has to bend a DVI cable. But, DVI is getting phased out in more and more display cards. And, DP and HDMI cables are much easier to bend. If one has to, just get a 90-degree adapter/cable will do.
I think this is just a minor issue.
Poblopuablo
816
465
It's dimensions are messing me up. 160mm wide but only 120mm for CPU cooler Clearence? That can't be right. And 300mm long, but only 280mm GPU?
ChrisMCP
49
Yeah I get it it needs to go somewhere, top or bottom. Since they want to keep the top clean, they had to stick it in the bottom. Still I prefer Jonsbo VR1 approach to it when the top is masking all the cables. This way you don't have the hdmi coming from the bottom and the rest are at the centre of the rear.
