What did you do today?
6,075
5,007
I left work early, I take back my overtime usually on fridays. And what am I planning on this moist day ? Not spray-painting my case project, that's for sure. Maybe look into compressor spray painting guides and probably gaming. Most likely gaming. Gaming.
QinX
kees
Mar 2, 2015
541
374
Perhaps you could set a timer to ensure that you get some food and rest, Mr. Factorio.
Don't worry any expert factorio player has an express belt with a stack insert that starts feeding you when "energy <20" and stops when "energy >100"
Reactions: Soul_Est
Soul_Est
1,536
1,928
Um...
Yes to that.
XD
I have decided to not be a lurker anymore here on the forum. Hello.
Hi! Welcome to our lovely abode and we do hope that you will make yourself at home as well.
Physical Therapy follow up and I think I'll probably spend the rest of the day cleaning, working on my blog/sites, and paying bills.
Joy.
You could get the physically demanding and stress inducing stuff out of the way first and work what on the good stuff. You could also intersperse the work on your blog and sites with the cleaning.
I am working on a 3D model in Blender and freaking out that the backlight on my self-built monitor is going to die soon (just realized that the controller is over-driving it).
GuilleAcoustic
Chief Procrastination Officer
LOSIAS
Jun 29, 2015
3,042
4,518
guilleacoustic.wordpress.com
No computer, nor TV, nor WiFi at hospital. Made this choice to force me out of procrastination.
Today, as everyday, I spent 15 minutes learning Japanese. I now know the first 10 hiragana :).
Drew a few chassis designs using 3 points perspective. I truly missed that feeling of building "volumes" with only a sheet of paper, 1 or 2 pencils and a ruler.
onlyabloke
178
193
pcpartpicker.com
Spent most they day cleaning the bedroom. Reorganizing the closet, throwing away an old beat up closet I bought a couple years ago (freed up so much space) and then cleaned the rest of the room up after the mess. Probably going to go through the wardrobe soon and donate all the clothes I don't wear or don't fit anymore.
Reactions: Soul_Est and Phuncz
SumGhai
147
175
Cracked my Moto X 2013 screen when it fell out of my pocket while on vacation in Penang, Malaysia. Will never carry a smartphone in shallow pockets again.
May take advantage of this by going to a local Oneplus 3 service center and seeing if I can't buy one here and bring it back to the US with me. For those who might know, are there any other Asia-market smartphones I should keep an eye out for? At least ones that I could take back to the US and use on AT&T network?
Soul_Est
1,536
1,928
No computer, nor TV, nor WiFi at hospital. Made this choice to force out of procrastination.
Drew a few chassis designs using 3 points perspective. I truly missed that filling of creating "volumes" with only a sheet of paper, 1 or 2 pencils and a ruler.
Remove distractions and focus on what's important. I need to do that more often.
I am working on a couple case designs as well as ideas for integrating Kodi, RetroArch, and Steam.
Soul_Est
1,536
1,928
I am so sorry. You could take a look at the LeEco Le 2, Le 2 Pro, or LeMax 2 or the ZUK Z2 or Z2 Pro.
6,075
5,007
(yesterday) I did what I do weekly on saturdays: clean my espresso machine. It thankfully has a three-way valve so I can use backflushing instead of removing several components and soak them in coffee detergent.
Manual way:
Backflushing:
I also did some searching about compressed air spray gun setups, since I have a decent sized compressor and gravity-fed spray gun available to me. I'll be looking into a pressure regulator with a water and oil filter built-in, but I was also thinking about "spray tents", since I don't want the paint particles all over the place and car. So I was thinking a spray tent where I can stand and is big enough for PC cases or even small furniture. But not only would I need the tent, I would also need to spot to put that in which is an issue. Also, I'd fully have to suit-up every time I'd go in. Considering I've sprayed and wet-sanded my motherboard tray about 15-20 times, this doesn't look like something I'd do often.
So I'm thinking about just a tent for the object, removing the "fourth wall" with a screen (with a hole) instead and have a fan with a filter at the top and bottom. This way I could create overpressure with a slightly higher input than output fan speed, but make the paint particles go through the filter on top instead of out the screen.
I could use my cheap collapsable photo tent (looks a lot like this) for that even, I'd just need to make a PVC pipe frame for mounting the fans, get some nice 300mm fans and some filters (from an kitchen's "exhaust hood", learned that today), along with a way to put it all at the correct height.
I'll be going to need to look into this, but any suggestions on how to tackle a spray gun at a low pressure, outside without covering surrounding areas in spray particles, I'd be very grateful.
iFreilicht
FlexATX Authority
Feb 28, 2015
3,243
2,361
freilite.com
Nice, my parents had those exact coffee machine since 20 years I think and got a second one 10 years ago. The guy who repairs those every other year refuses to sell them any other coffee machine, no matter how expensive, because he says there is no coffee like the coffee from the Gaggia classic.
Lolol. Do you have empty instant noodles box stacking all over your desk ?
For those you've got conveyors as well ;)
Soul_Est
1,536
1,928
Did a lot of research for my designs. RX 470 looks like the RX 480 which is good but should be easier to shrink due to the lower amount of power phases.
Yes, I have a lot of tabs open for researching various subjects. The RX 460 and WX 4100 however have me quite excited.
Smaller GPUs for all!
GuilleAcoustic
LOSIAS
Jun 29, 2015
3,042
4,518
Added details to my Simplicity chassis drawing. Then I took a photo of it and colourized it with the Autodesk Sketchbook Android app.
The white thing at the bottom of the SSD in an handle for the SSD caddie.
Edit: Next step is cooler, SFX PSU and cable.
Edit²: Then bottom and top panels XD
Edit³: Then 3 points perspective XD
Soul_Est
1,536
1,928
Looking good! The layout will definitely help with airflow through the system. Also, the new Radeon Pro cards are coming out soon.
CC Ricers
2,234
2,557
RX 470 and 460 look exciting for small form factor cards. Also those low-profile Polaris workstation cards! Though I imagine those will cost way more.
I am sorry to read that. If you'd like, you could apply to work remotely with either Basecamp (https://weworkremotely.com) or Buffer (https://buffer.com/journey).
I've worked remotely with my last company, actually, and willing to do it again. I've gotten a few interested parties from weWorkRemotely interested, but no offers yet. Buffer looks like an interesting company, but no software engineering positions ATM but I'll check back later. Do you have any association with Buffer?
Reactions: Soul_Est
Soul_Est
1,536
1,928
The Wx 4100 will cost <$500 USD while the WX 5100 and WX 7100 will cost <$1000 USD according to PCOnline (http://diy.pconline.com.cn/818/8182303.html). I do not have any association with Buffer (either fortunately or unfortunately).
