The purpose of this case is to be the smallest case that can fit a standard Mini ITX motherboard, 65 W TDP CPU cooler such as the Noctua NH-L9a/i, and DC-DC power supply such as the Pico PSU.
Top priorities:
Such a case will be able to house systems to be used for office applications, entry level gaming, entry level CAD, etc.
This case will only be 1.6 L in volume. To put the size into perspective, the 2018 Mac Mini is 1.4 L (13% smaller).
Target price point: 50 USD
What features do you think should be implemented?
Top priorities:
- Size
- Appearance
Dimensions: 176 x 173 x 54 mm
External volume: 1.6 L
Material: 1.5 mm anodized aluminum
Weight: 0.36 kg (0.8 lb)
CPU cooler clearance: 37 mm
Storage: M.2 only
PSU: direct plug in DC-DC (160 W max)
Storage: M.2 only
